piston to valve clearance?
Old Feb 26, 2009 | 07:21 PM
DaInFaMMuS1's Avatar
Default piston to valve clearance?
I searched this topic, but couldn't find an answer. So I'm hoping u guys can help me.
If i put H22 Type-S pistons, DH racing headgasket, and flat faced valves in 1 of my H motors, either a JDM H22a or an H23a vtec, to raise compression will i have issues with piston to valve clearance or any other issues? If so, how would i go about solving that, by modifying the pistons themselves? I would be running skunk2 stage2 tuner cams with the setup, so it wouldn't be a stock piston to valve clearance. The DH racing headgaskets measure at .0014. So I'm under the impression the Type-S pistons would stick out farther than usual with that thin of a gasket and that aggressive of a cam, and maybe i should just stick with stock valves to see if they would have better clearance although i wouldn't gain a compression bump from them. Anyone got any answers?
Old Feb 26, 2009 | 07:56 PM
ruffrhyder's Avatar
Default Re: piston to valve clearance?
Hope this helps
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-v2v-p2v-1891614/
Old Feb 26, 2009 | 08:07 PM
damn thats alot to do lol. I don't have any of the motors disassembled yet, I just wanted to know before i went out and finished buying parts :/
Old Feb 26, 2009 | 10:11 PM
SP GARAGE's Avatar
pm me
Old Feb 27, 2009 | 10:25 PM
PM'ed.
Anyone else got any input?
Old Feb 28, 2009 | 01:11 PM
squeezedeghatch's Avatar
clay your motor! dont take someone elses second had knowledge, its not difficult. get some body clay and a 6in rule/depth gauge and there ya go. c-speedracing.com.
Old Feb 28, 2009 | 01:23 PM
DonF's Avatar
If you do not have the time/ knowledge, don't do it, stay stock.
Old Feb 28, 2009 | 07:30 PM
promotor's Avatar
yeap donf is right stay with stock
Old Mar 1, 2009 | 10:51 AM
Once i get the procedure down pact, i'll def check em. Just wanted to know if anyone had answers beforehand. I'm not gonna do the valves anymore anyway, i'll go stock valves w/oem 2 layer gasket, and work with that.
Old Mar 5, 2009 | 03:15 PM
littleredbox's Avatar
New User
I have a jdm h22 with bc stage 3 all motor cams, bc springs and retainers and dh racing headgasket and valves. I have no clearance problems at all degreed cams to i think 2 deg. adv.
Old Mar 6, 2009 | 04:21 PM
NAH2B's Avatar
no, do not run skunk stg.2 tuner cams w/ stock valve pocket pistons.
and stay away from dh racing alltogether.
Old Mar 6, 2009 | 06:40 PM
GoldLudeRay's Avatar
i am running skunk 2 tunnner stage 2 cams with stock type s pistons
i measured the p2v with no head gasket and the head had been resurfaced and it had clearence ,it was tight probally like .008-.005 to tight but this was with no head gasket... so even with a head gasket it is close
but it was clearence,,,,it was also tested it with the cam gears agressive probally
more agressive than the cam would require......
i just broke the motor in too and have had no problems with p2v
i hit vtec more than once too,, i pulled the head no pitting on the pistons,valves look good...
stay tunned to dyno results on my set-up
it is an approx 12.0.1 cr motor,h22 on e85 with n20 also
Old Mar 6, 2009 | 06:43 PM
also,, maybe my motor has something different going on with it,,,
nah2b do you have any insite on the clearence on of the stg 2 cams
i know the type s piston stick out far,,,, but i have tested it and car is currently running
right now,,, getting ready to dyno in like 10days,,,,, im sure i tested it correctly it was locked in vtec when i tested.....just looking for an expericenced opinion,,,,, it has eagle rods,,
Old Mar 7, 2009 | 03:31 AM
up
Old Mar 7, 2009 | 04:00 PM
95skunkedgsr's Avatar
is this for any motor or just the h22 i plan on clayin mine and cheking v2v clear , but its also a gsr not h22
Old Mar 7, 2009 | 05:41 PM
f20b jones's Avatar
I have a h23 crank h23 rods type s pistons skunk2 stage2 cams and my block is milled .005 my cams are advanced 4 degrees intake and exaust.I am running a stock head gasket and i have had no problems and i got one thousand miles on it so far hope this helps.
Old Mar 9, 2009 | 05:09 AM
up
DougieFreshZero
Acura TSX
Jan 12, 2009 05:29 PM
FATBOYeg6
Mar 17, 2008 02:17 PM
allnapower
Dec 21, 2004 07:04 AM
96SR-V
Mar 22, 2003 06:48 AM
wade95gsr
Jan 27, 2003 07:51 PM
