hubcentric rings for jetta rims?
Old Feb 26, 2009 | 07:04 PM
GsDAteg's Avatar
Default hubcentric rings for jetta rims?
I just got some rims off a 92' Jetta for my DA and they have a center bore of 57.1mm. Do I need to use hubcentric rings? If so, where can I find some that go from 57.1 to 56.1?
Old Feb 26, 2009 | 07:11 PM
r.wright's Avatar
Default Re: hubcentric rings for jetta rims?
i wouldnt use any and im not even sure if they make them in that size. your only choice would prolly be custom made metal ones..
Old Feb 26, 2009 | 07:23 PM
GsDAteg's Avatar
That's what I was thinking because I can't seem to find any in that size. But it looks like I was a little off though. The rims came off a jetta which is a 57.1mm, and that is what the seller said they wheels were, but I just measured them with a ruler and they measured 2.5". And when converted that would come out to 63.5mm. So is it still reccomended that I not use any hubcentric rings?
Old Feb 26, 2009 | 09:14 PM
r.wright's Avatar
i would try the wheels on as is and if you dont have any vibrations then i wouldnt even bother w/ the hub rings. most vdubs almost require the rings for centering since they use lug bolts opposed to our lug nuts.
hybrid90
Oct 26, 2009 07:35 PM
JoshuaVTEC
10
Oct 30, 2005 09:07 PM
slowpokesi
Jul 24, 2003 09:03 PM
Ya@inlinePRO
May 7, 2003 11:07 AM
itr501
Apr 26, 2002 03:58 PM
