Cap not holding pressure? bad seal
Old Feb 26, 2009 | 05:39 PM
Singlecam4dr's Avatar
Default Cap not holding pressure? bad seal
Ok so my cars not overheating, but the radiator cap is not holding pressure. Theres no coolant in the overflow and i think it may be leaking from under the timeing belt cover. Is it a bad seal or is the pump on its way out? Any advice is taken readily thank you in advanced.
Old Feb 28, 2009 | 04:31 PM
Default Re: Cap not holding pressure? bad seal
bump1 ttt
Old Feb 28, 2009 | 04:43 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Typically when you have the described problem it is that the pump is bad. When the seal/impeller messes up backpressure will result and overflow will occur.
The leak from the timing cover is probably from the weep hole on the water pump. This is the indicator for when the bearing/seal goes bad in the water pump.
Old Feb 28, 2009 | 05:05 PM
93formula's Avatar
yup time to change the waterpump and timing belt while your there.
Old Mar 1, 2009 | 04:32 PM
Damn ok thats what i was affraid of. Thanks guys , n i already replaced my timing belt so at least it'll be a little cheaper.
Old Mar 1, 2009 | 04:44 PM
93formula's Avatar
typically thats why when one replaces the timing belt they replace the waterpump while they are there...
Old Mar 1, 2009 | 06:19 PM
Ya i know i didnt have the cash after my harness. Oh well this is what i get for it.lol
cptmoney
Apr 23, 2014 08:18 AM
Barf Hat
Apr 4, 2012 10:52 PM
5.56
Jun 17, 2009 05:19 PM
vtek9
Sep 2, 2007 09:55 PM
Wayne_Curr
Mar 27, 2006 11:18 AM
