De-Buring a block...
Old Feb 26, 2009 | 04:50 PM
EG Coupe Frank's Avatar
Default De-Buring a block...
Has any one here deburred their blocks? If so does anyone have any tips? Im just gonna practice on an old block. I want to chamfer all corners I can reach in the oil passages. Pictures would be nice, and tool choice also would be nice. I was thinkin dremel, rat tailed file, and a drill. I want to focus on the crank journals. any help or pictures would be awesome.
Old Feb 26, 2009 | 06:21 PM
Default Re: De-Buring a block...
Im gonna email endyn tomorrow. I will make sure to photograph everything and post a good how to.
Old Feb 26, 2009 | 06:22 PM
Rob_O's Avatar
I think there are some pics on the endyn website
Old Feb 26, 2009 | 06:30 PM
Yeah thats where my insperation comes from.
Old Feb 26, 2009 | 06:34 PM
paulwall90's Avatar
i used deburr blocks at my old job,and i only used a die grinder!
WhiteSol's Avatar
That was on a dart block, where the casting and machine finish was not up to honda-spec standards...
Old Feb 26, 2009 | 06:39 PM
Yeah read that whole write up, however the crank bearing oiling holes still need work, and if you have ever looked down the oil passages in a honda block you will see some flaws. Im talking about chamfering the leading edges on he oil passages I can reach and cleaning the intersections of oil ports i can access. No block is perfect not even honda blocks.
Old Feb 26, 2009 | 08:14 PM
Turbowa's Avatar
If your going to drill out the oiling hole its best to use a uni-bit. It will leave ne burr's on the bearing and will drill it clean. Just be very careful to make sure its perfectly centered with the hole.
Old Feb 26, 2009 | 08:22 PM
thank you for the positive input.
Old Feb 28, 2009 | 07:42 PM
No word from endyn
Old Mar 1, 2009 | 09:22 AM
iskate2's Avatar
+1 on th unibit. im not familiar with de-burring blocks, but unibits are really good at enlarging passages and rounding sharp edges in one step.
Old Mar 1, 2009 | 01:15 PM
Thanks again. de-burring refers to mremoving any casting flaws.
Old Mar 1, 2009 | 01:26 PM
Combustion Contraption's Avatar
Deburring is not the same as enlarging oil passages. Deburring is just getting rid of casting flash, sharp edges, etc. ENDYN probably does'nt have time to answer any emails that dont regard him selling something, which he absolutely should'nt have to, I'm the same way.
Old Mar 1, 2009 | 01:36 PM
I understand that and I explained that in the email I sent them. Notice I didnt fire out at Endyn I mearly said that they hadnt gotten back to me yet, nothing bad said. I also dont hold anything against them and still plan on buying parts from them becasue they have some of the best parts on the market. I appologize if theres abything I said that offended you.
I do understand the differance between deburring and porting oil passages. I had just stated that in the ports that flow oil from the head back to the oilpan there have been castingflash in three of the three honda engines I have torn down.
Old Mar 1, 2009 | 03:34 PM
4g hatch's Avatar
there is a few very knowledgable people on here if you are serious. i know donf is the one person i turn to when im looking for advice on engine building. some people just forget where they came from and that they started somewhere. also they forget that they where in your's and my shoes at one time,just wanting advice that doesnt have a price tag on the end of it.
good luck on you project. i wouldnt mess with the crank oiling holes. i would assume its very easy to do more damage than good
Old Mar 1, 2009 | 04:34 PM
Old Mar 1, 2009 | 04:54 PM
ENDYN's Avatar
The Old One
Endyn hasn't received an email concerning this subject....
Old Mar 1, 2009 | 07:09 PM
You are correct it is still in my microsoft outlook outbox. Well its sent now (I hate outlook). A local machine shop said they can help a little, however they specialize in circle track 350 and 5.0s. They said I have to be pretty specific on what I want them to do. They have a pretty impressive record, however i think they want me to just go away. Haha, they still cant see we are all in the same game no matter what badge is on the front of your car.
ejeffone
Engine Machining & Assembly
Nov 12, 2019 08:12 AM
GarageAlchemist
May 25, 2007 01:58 PM
em1 Ziggy
May 12, 2006 11:08 PM
mo0cow
Oct 26, 2005 04:36 AM
