Water line CAPS
napa carries them, but I have read several instances of the jeep guys complain because they dont last very long and have to be replaced aevery couple of months.....however if your not submerging your vehicle every weekend I dont think it will be a big deal...
From: Between the hills of Downtown LA and Pasadena
Why not weld some of the shut or drill and tap and place a plug in there? for the water lines on the water tube I had them welded and the ones on the thermostate housing, I removed the elbows and drill and tapped and I was done with it.
For the one off the head by the vtec solenoid you can use the allen head that is used to hold the rocker arm shafts.
Frost7177
Oct 5, 2009 06:07 PM
