Endlink Q's with LCA (BLOX Style)
Hello, I just took a look through the archives and didn't find the answer I was looking for. I can't post pics since I'am at work, but if it's nessecary I will post some later. The car in question is an 89 CRX Si. I just installed PIC Selects and decided to replace the LCAs with some similar to the BLOX arms w/ the sway bar endlink hole in the center of the arm instead of the upper portion of the arms like oem. Well If I try to bolt the stock endlink to these arms the endlink will be at a very extreme angle, and the bushing don't make proper contact with the LCA. So I read somewhere, telling me to use washers in the recessed area of the hole. How many washers should I use? I used a longer bolt and a 2inch stack of washers, so now the stock endlink is at a 90 degree angle instead of a 45 degree angle. Will the angle of the endlink affect the characteristics of proper sway bar movement? Should I remove the stack of washer and bring the endlink closer to the arms. Will this distance increase the stiffness or soften the swaybar? If you cant figure out what the heck I'm talking about , let me know and I try and get some pictures, or at least make some in mspaint. Thanks for the help fellow EFer's
vegaskurt
Jun 30, 2005 09:55 AM
