Coilovers or Springs?
Old Feb 25, 2009 | 09:40 PM
S A D A N's Avatar
Default Coilovers or Springs?
Coilovers or springs?... Whats recommended? and what is the diffrence? sorry im new and have lots to learn thanks!
Old Feb 25, 2009 | 10:54 PM
93formula's Avatar
Default Re: Coilovers or Springs?
search theres tons of info, depends on budget and what your gonna use the car for....
Old Feb 25, 2009 | 11:21 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Search.
Old Feb 25, 2009 | 11:32 PM
My_EFsedan's Avatar
i perfer coilovers so you can raise or lower any time you want..ive used springs before and it just doesnt seem to go to low as you want, leaving those open gaps between the tire and fender..but thats just me..whats your purpose for the car, budget and goals?
Old Feb 26, 2009 | 10:49 AM
cmgibby's Avatar
what ive heard and read;
Coilovers are more of a race setup, i.e. auto-cross
springs are more for show. lowering springs give no or very little performance advantage.
the price diff is tremendous, springs are $200-$300
coilovers for a decent setup will be over 1K
Old Feb 26, 2009 | 10:53 AM
jhammond_82's Avatar
Reject Papi
ebay coil overs and decent struts will be just fine for a daily driver. thats my opinion though. if you think you need to spend 1k on coilovers, **** an ef and get an s2k!
Old Feb 26, 2009 | 11:26 AM
TOUGE4LIFE's Avatar
NO LEGS
Guy, I have noticed that most springs offer a softer ride than most coilover type set-ups. I have Tein S techs on my CRX they ride great, but I would like the car lower. Thats why I am looking into coils. If it is a daily car I would suggest springs, if you want a good drop on spings look into H&R Race springs. They give a decent drop for springs and they ride better than any Coilover equipped car I have ever drove in.
Always remember when lowering a car, its not just the sping that matters look into shocks as well. If you put aftermarket springs or coils on your car your shocks will blow, its only a matter of how long it will take. So take the time and extra $$ when you buy and install Coils or Springs pair them with A good aftermarket shock. From my own experience I highly reccomend Koni yellows, they are pricey but they are worth it. Warrantys are your friends!
If you don't have that kind of cash to spend on shocks alone, look into Koni orange's. I have a freind who is using them and they work great on his daily.
Youy can have a great coilover set-up for less than 1K. Look into omni coilover sleeves with Koni yellows. It should run around 750$ and you can adjust it all you want with no worrys.
Old Feb 26, 2009 | 11:44 AM
93formula's Avatar
progress has a street full coilover set up for around 500.00 check them out.
Old Feb 26, 2009 | 12:35 PM
mike-y's Avatar
wrong. it all depends on what your buying. there are springs made for comfort, and springs made for performance. A good performance spring with a good shock will perform better than a cheaply made coilover setup.
springs will usually be cheaper and will lower your car a fixed amount. some lower than others, it just depends on which ones you buy. performance springs should also be paired with an aftermarket shock that can handle the new spring rate.
an adjustable coilover system is a combination spring+shock that usually has an adjustable spring perch. This means you have a range of lowering adjustment (like .5 inch to 3.5 inches) that you can set yourself. Some coilovers are more performance oriented than others, again it depends on which ones you buy.
and then there are coilover sleeves that you slip over a conventional shock that gives you height adjustability, and usually a choice between different spring rates.
Old Feb 26, 2009 | 12:53 PM
allmotorh22crx's Avatar
coilovers are better that what i think...more expensive though ....slaaamm it!!
Old Feb 26, 2009 | 01:36 PM
mos's Avatar
mos
Even with soft springs, coilovers don't really ride that comfortably. Yeah, it didn't make sense to me either, but that is what I experienced with my car. I've heard the same from another guy. I forget who it was, but I sold him my 350f/250r springs. He put them on a heavy prelude coming from higher track rate springs. He was all like "wtf it still doesnt ride smooth with these low rates" and I was all like "yeah dude, on my car neithers" and he was all like "that sucks" and I was like "yea."
Old Feb 26, 2009 | 03:03 PM
murphy lee's Avatar
I preferer springs !!!! Coilovers are too bumpy and unconfortable!!!
Old Feb 26, 2009 | 05:19 PM
Reject Papi
a guy in the mid atlantic for sale forum has some k-sports, bnib for pretty decent price. not a bad brand either. 560lb front and 336lb rear. that would be a pretty good ride i think. and it would handle like a ****.
Old Feb 26, 2009 | 05:48 PM
xileap2's Avatar
i prefer coilovers. just for the fact that you can adjust to whatever you want. I cant wait to finish my KRX and feel the koni/gc. spring rate 500f/550r
Old Feb 26, 2009 | 07:17 PM
S A D A N's Avatar
yeah seems like coilovers are better but the $$$$$.. i want to lower it pretty low.. but seems springs dosent lower it that low or something cause my friend put some on.. and it looks like he didint even lower the car.. hmmmm
Old Feb 27, 2009 | 04:17 AM
Reject Papi
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem= there, i just bought them. cheapest ones on ebay that i could find. i'll let you know how shitty of a ride they are when i put them on.
Old Feb 27, 2009 | 01:46 PM
xci_ed6's Avatar
4 troof
Old Feb 27, 2009 | 05:34 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
You really just have to decide what you want to use the car for. I've got some Sprint springs on my sedan daily driver and I love them. Decent drop, nearly OEM ride quality and improved cornering.
Old Feb 27, 2009 | 08:42 PM
S A D A N's Avatar
yeah the car im going to lower is going to be my daily driver... i just found some skunks for a pretty good price.. and its free shipping ..
http://cgi.ebay.com/ebaymotors/_Car-...ayphotohosting
Y-eight
Jul 22, 2011 11:06 AM
JrEk9
Suspension & Brakes
19
Nov 24, 2009 02:26 PM
03EXHondaOKC
Honda Civic (2001 - 2005)
Mar 11, 2009 01:56 PM
gsrguy
Feb 2, 2004 05:38 PM
