sohc zc swap help. 1 vac line and what is this? :pics:
Ok so let me star with the car. it was an automatic with a blown d15b2 so i swaped parts for it to be a manual and i wired up mpfi then i bought a soch zc with an si transmission for 450. i bolted the motor in and now i have a question on where this line goes
that is the line, it starts their. below the resinator box plug and cable for the manual transmission.
and laying on top of everything it is this long.
<br>
<br>
And what goes here? vtec noid? because the guy i got the motor from said it wasnt vtec, like all obd0 zc's
This is intake side of the head close to the distributor.
Thank you so much.
where is the head code stamped?
<br>
<br>
Thank you so much.
Line looks to be the fuel return line it goes on the pressure regulator on the end of the fuel rail. That spot is for the mechanical fuel pump. Motor was most likely originally carbed.
yup what he said, fuel return and the mechanical fuel pump location, block that off with some sort of plate fabbed up, make sure you have a good seal or you will leak oil out of there...
okk so homeade gasket and have a plate fabed up and bolt it over the hole.
And the line? would i jut block that off aswell.
<br>
<br>
Thank you so much.
<br>
<br>
Thank you so much.
Looks like you are missing the fuel pressure regulator on the fuel rail.
Near the close end of the fuel rail I can see two screw holes and one larger hole between them.
The hose you are asking about is your fuel return
- and -
You should also have a smaller tube for vacuum that isn't connected.
That tube would go to the FPR as well.
Should look something like this
- and -
[QUOTE=4drEF;37564697]Looks like you are missing the fuel pressure regulator on the fuel rail.
- and -
yes thank you. is the vac line from the intake manifold?
- and -
crxdriver89
12
Feb 28, 2006 10:00 PM
