OEM ITR strut bar question?
so i jsut picked on up for 50 bucks, kinda forgot which direction it went or it doesn't matter? and also what bolts do i use? 14 mm( i'm guessing)
ITR's don't use bolts to mount the tower bar. They have 4 studs welded to the frame that bar slips over. Then you simply spin some nuts onto each stud and be done with it...
If your car just has holes, use whatever nuts & bolts fit. You might wanna put some washers in there too. Make sure the heads of the bolts are on the bottom side cause you don't want the threaded end to dig into your tires over bumps...
ok thanks for answering my next question, i didn'tknow whether the bolts go downward or from the bottom up..
well since i have to go from the bottom up, don't i have to remove the fenderlining to get under that part?
i'm sorry, I jsut posted in the ITR section since all of you guys have this bar, and most ppl in the integra forum dont. ok, for installation, I jsut need to take off the wheels and then stick the bolts from bottom up?
