FS: B16 motor, tranny, swap parts, etc.
Old Feb 25, 2009 | 06:47 PM
MiMiK's Avatar
Default FS: B16 motor, tranny, swap parts, etc.
Parting out my swap/car. All prices are OBO.
B16A motor - $700
JDM B16A block(stock)
ARP headstuds
freshly rebuilt, lightly ported PR3(B16A) head
REV valvesprings & titanium retainers
stock b16 cams
Skunk2 adjustable cam gears
moon-cut 'Mugen' valve cover(powdercoated red)
B-series auto. starter - $20
Walbro 255lph fuel pump(used for 5 miles) - $80
OEM ITR intake manifold - $120
OEM Del Sol VTEC intake arm & box w/ K&N filter(brand new) - $50
2.5" test pipe & exhaust for 92-00 coupes - $120
P06 ecu, chipped - $120
P06 ecu, virgin - $60
OEM B-series flywheel - $30
OEM Integra GSR leather shift **** - $20
92-95 Civic LX gauge cluster(auto., tach. w/ 6500rpm redline, but shows rpm's until 9000) - $40
92-95 Civic EX cluster(auto., tach. w/ 7200rpm redline, but shows rpm's until 9000) - 40
I might be forgetting some things.. best way to contact me is to call me. My number is 305-720-5111 and my name is Mike. Or you can PM me. I check this a couple times a day. If you need pics, just ask.
sold:
JDM EG6 corner lights
USDM EG hatch taillights
Megan Racing 4-1 JDM style header, 2.5" collector(repaired and strengthened on bottom 2 primaries)
B-series manual starter
OBD1 B-series alternator
rear T-bracket for b-series swap
B&M adjustable fuel pressure regulator
ITR throttle body (taper bored to 66mm)
B-series shift linkage
Del Sol seats(green stripe)
JDM EG6 headlights
OEM ITR flywheel w/ bolts
used Exedy stage2 3 puck sprung clutch w/ pressure plate
Innovative Billet urethane motor mounts(red inserts) for eg/dc. 2 bolt post mount
OBD1 dizzy w/ brand new OEM Honda ignition coil - sold to TECHMONG
P28 ecu, chipped - sold to TECHMONG
Endyn Bump-Stix(12.6mm in. lift, 11.6mm ex. lift)
Halfshaft w/ axles
Del Sol S21 B16A3 transmission
used OEM clutch & pp
Old Feb 26, 2009 | 06:55 PM
MiMiK's Avatar
Default Re: FS: B16 motor, tranny, swap parts, etc.
bump
Old Feb 27, 2009 | 10:08 PM
MiMiK's Avatar
top
Old Feb 28, 2009 | 05:04 PM
MiMiK's Avatar
updated
Old Mar 1, 2009 | 05:04 PM
MiMiK's Avatar
updated.
Old Mar 2, 2009 | 08:15 AM
94sihatchy's Avatar
bump
Old Mar 4, 2009 | 05:30 PM
MiMiK's Avatar
thanks for the bump!
Old Mar 6, 2009 | 11:02 PM
MiMiK's Avatar
up.
Old Mar 9, 2009 | 06:45 PM
MiMiK's Avatar
up again.
watisjdm
Mar 29, 2012 09:19 AM
R.and.Y
Apr 9, 2009 12:13 AM
