Obd-0 --> Obd-1.....need help
Old Feb 25, 2009 | 06:42 PM
ltrecrut's Avatar
New User
Default Obd-0 --> Obd-1.....need help
Hi,
I want ton convert my B16a first gen. 0bd-0 to obd-1.
I have search for a how to..But I have find nothing.
I have:
-Distributor Sir Obd-1 second gen.
-Harness convertion 0bd-0 to obd-1
-P75 chipper ECU for run Sir
is missing something?
I think I need also o2 sensor..But I want tu run my car without o2 sensor.
how made it?
Finaly last question.
The guys has who buy the car...Have cut and top up some wire in the engine harness..And now the car don't want to start.
So I want to convert this Obd-1 for run it.But the engine harness is **** top...
therefore I buy engine harness 92-95 v-tec but the plug doesn't fit with the chassie arness plug
It is possible to instal eg chassis arness in a ef??
Old Feb 25, 2009 | 06:46 PM
ONE-CAM-EF's Avatar
Default Re: Obd-0 --> Obd-1.....need help
i think you cant run a engine without a o2 sensor...its going to run with a CEL and that means no vtec from what i know....you also need obd1 injector's and the clips
Old Feb 25, 2009 | 06:49 PM
ltrecrut's Avatar
New User
obd-0 and obd-1 dont have same injector?
Old Feb 25, 2009 | 06:51 PM
es.roadster's Avatar
hey i just finished converting my hatch to obd1. took me a couple of hours but i got it.
well to answer your first question, yes you'll need an o2 sensor but if you don't want to run a your car without a o2 sensor, i think you can get your ecu reprogrammed at a performance shop. just take your time and don't take any shortcuts.
lastly, if you want to use the eg harness, you'd have to take out your dashboard and rip out your old ef engine harness and swap it with the eg one.
i think the problems that you'll run into is that the eg plugs will not fit into some ef sockets and also you wasted money on the jumper.
take your time and goodluck!
Old Feb 25, 2009 | 07:14 PM
1stgenboost's Avatar
english owns you.
Old Feb 25, 2009 | 07:25 PM
D16SiHatch's Avatar
^ha, yes i concur
if you want to use the eg engine harness, then you will need the eg cabin harness as well. and the eg harness will not connect to your dash. you'd have to swap to an eg dash. this would be a giant pain in the dick, which is why i advise you not to do this.
you will need to have the o2 hooked up and functioning, otherwise vtec will never engage, not to mention the other problems not having an o2 hooked up causes.
obd0 and obd1 injectors are different, but not in cc rating in most casing. its just the fact that obd0 injectors are peak and hold and require the use of a resistor box. if you use obd1 injectors then you can delete the res. box. either way you go you'll accomplish the same thing so it doesn't really matter.
Old Feb 25, 2009 | 07:40 PM
Originally Posted by 1stgenboost
english owns you.
me?
dc5itracer
10
Mar 26, 2011 10:29 AM
efjones9
20
Dec 30, 2008 04:31 PM
slammedz6ef
Dec 31, 2007 04:13 AM
nitewolf
Sep 3, 2007 07:03 AM
tsr2
14
Dec 2, 2006 10:23 AM
