CAI Install Question!!
I have my airbox and hose removed, and in the AEM instructions it says to remove the water bypass hose from the throttle body or the fast idle thermo valve. I'm more of a visual guy so I'm kinda stuck right now. Where exactly on the throttle body are these components? I have a 97 GSR. Any quick responses will be greatly appreciated.
On the stock intake, there is a hose that runs from the intake tube to the valve cover, this is your PCV hose. There is bracket holding the PCV hose and another hose. That other hose is the water bypass hose. Follow it and you will see where you need to remove it from. HTH
ShinotakuX
May 14, 2008 09:55 PM
2000vsm
Aug 25, 2003 07:14 PM
