Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Cleaning the Carpet
Old Feb 25, 2009 | 07:10 AM
Whatislove's Avatar
Default Cleaning the Carpet
My interior carpet is done for. Its a terrible mess, previous owner didn't use mats at all.
Besides having to remove all the molding, seats and center console, are there any other challenges to removing the carpet?
Also, can this thing be taken to the cleaners or just washed in a washer, or are there glued parts that will deteriorate. Replacement carpet aint cheap
Old Feb 25, 2009 | 08:59 AM
tonykdee's Avatar
Default Re: Cleaning the Carpet
my local dealer is having a promotion where they wash and clean your carpet for 50 bucks. maybe you can check your dealer. i thought it was a good deal considering all the product you have to buy anyways plus your time.
Old Feb 25, 2009 | 09:01 AM
Whatislove's Avatar
I dont mind the time. THe product yes, majestic wont ship the damn carpet and local dealers have a 50% markup so its almost $300...
My carpet aint torn, but just in really bad shap filled with dirty and discoloration
might have to find someone to clean it while its inside
Old Feb 26, 2009 | 02:44 PM
03em2ssm's Avatar
take it out and throw it i the was. I did that with my rear mat
Old Feb 26, 2009 | 04:16 PM
DynastyRacer22's Avatar
take it out and wash it down really good then use carpet spray and paint it thats what i did with mines and then went on handaaccessories and ordered the floor mats from them for 50something bucks and look good as new
Old Feb 27, 2009 | 05:54 AM
Maple50175's Avatar
send me the cash and ill go to majestic get it and ship it out for you. Just throw me an extra 50$ for my time lol.
What we do here at honda is spray some cleaner on it take a hose and soak the bitch then vacuum it up and leave the heat on and bang clean carpet
Old Feb 27, 2009 | 01:01 PM
TYPE_RR's Avatar
that's not bad to fix... unless you want to go all out.. just buy some cheapp auto carpet,.... and cut correctly and gun glue thhem on,,, i meann it worked well for my car.... but i got some help. carpet- walmart, scissors- home, person- my husband. it worked out good:D
Old Feb 27, 2009 | 01:04 PM
TYPE_RR's Avatar
oh, if you are planning to wash the carpet... i have non idea on that... hehe im a cheapstake...:D but that seems to cost more then what i did... i mena its not the original carpet but heyyy... it looks wayy nicer:D
Old Feb 27, 2009 | 01:12 PM
iiPancho's Avatar
I took my entire carpet out, soaked and scrubbed it with automagic
borrowed my grandpas truck, tossed it in the back and drove up to a car wash, and took it to the self wash part. and pressurewashed it with hot water.
looks brand new.
Old Feb 27, 2009 | 02:17 PM
theineffable's Avatar
If you're going to soak the carpet, take it out of the car before cleaning it. Afterwards, make sure it's dry before putting it back in. You don't want the carpet underlay to be wet while it's in the car. This is because the carpet has a waterproof plastic layer that won't let water escape from the underside of the carpet.
Anyways, I think you should try cleaning it first then if that doesn't work, go buy a new piece. You might have some luck if you go to an autowrecker. Most carpets will be all moldy from rain but you might find a good one if the car is a new arrival.
Old Feb 27, 2009 | 02:58 PM
iiPancho's Avatar
I have never seen a Junkyard carpet in good condition. This was a civic I picked up at a junkyard, look how gross the floor mats are, under the mats is 100 times worse.
EDIT: I find you can find some really reliable cars from a junkyard just not the cleanest.
Also a guy mentioned to me of a product called "folex" I heard it was the bomb.
Old Feb 27, 2009 | 03:24 PM
spoonfedcrx's Avatar
Take that **** out, hang it on a fence and hose that **** down with everything you got. Then pressure wash the fu.ck out of it, let it dry, reinstall and treat yourself to new floormats. You deserve it after all that work and your car will thank you.
Old Feb 27, 2009 | 06:18 PM
dr_spock's Avatar
I took my home Bissell Big Green carpet cleaning machine to my used Civic. The previous owner had kids and the seats and carpets weren't pretty.
Here's the after cleaning the carpets and seats:
Used it in the trunk too:
Old Feb 28, 2009 | 05:30 AM
TYPE_RR's Avatar
wow,looks just brand new:D
CodyC142
Apr 25, 2007 06:57 PM
gsr-2nr
Mar 15, 2007 01:48 PM
Cuong-nutz
Feb 25, 2005 12:13 PM
AndyD
Aug 30, 2004 08:51 AM
Balls
Oct 28, 2001 05:58 AM
