14mm fuel injector port plug ?
Shot version of the story
Counter flow 8v vw head + old supervee ITB's = throttle linkage that hits fuel injectors even with a 1/2in gasket spacer.
(i am not using that fuel rail or those injectors)
I am going to be putting the injectors in the velocity stacks before throttle plates.
This leaves me with the old injector bungs in the head needing to be plugged. I would prefer to have a removable solution and not destroy the bung by taping them or filling them with epoxy/welding.
I found a picture of something along the lines of what I need, but the company is in Australia and doesn't have any in stock.
Unfortunately I don't have any exact dimensions but its just a standard bosch injector port. The oring is 14mm od and the hole is 8mm deep
it doesnt really need that piece that necks down at the bottom that would probably just help keep it centered when installing
blu3fan
Nov 16, 2012 05:05 PM
falcongsr
Mar 11, 2002 09:12 PM
