Idle at 3000 after throttlebody upgraded
Old Aug 10, 2002 | 03:45 PM
Fatty_1775's Avatar
Default Idle at 3000 after throttlebody upgraded
On a 2001 B18 with a jg edelbrock throttlebody, we replace the stock throttlebody with a 68 mm holley throttlebody. Now, the check light is on and it idles to 3000. It was working normally before we replaced the throttlebody. All connections were double checked. Any ideas? Thanks.
Old Aug 10, 2002 | 04:03 PM
RosebloodSol's Avatar
Default Re: Idle at 3000 after throttlebody upgraded (import_racer)
MAP Sensor? TPS? idle screw? these are all the items I would check.
Old Aug 10, 2002 | 05:26 PM
Fatty_1775's Avatar
When we put back the old throttle body, everything is back to normal.
Old Aug 10, 2002 | 07:58 PM
psi420's Avatar
Sounds like a vacuum leak, try a ITR TB Gasket.
Old Aug 11, 2002 | 07:28 AM
sjk's Avatar
sjk
Default Re: Idle at 3000 after throttlebody upgraded (psi420)
3 things come to mind.did the new throttle body come with a tps or did you have to swap?if swapped,it has to be adjusted correctly.a vacuum leak is possible.try spraying around the base with carb cleaner to see if idle changes.make sure air adjustment screw on the body is not adjusted to far out.i have come across bad
butterfly shaft bearing problems on some upgraded throttlebodys.hope this helps.
powerstrokeaaro
Aug 22, 2010 04:20 AM
ge_ej1
Jan 29, 2008 05:09 PM
924doorEG
Nov 19, 2007 08:15 AM
LSV84
May 13, 2006 01:16 PM
delSolLS
Feb 18, 2002 04:59 AM
