Question 91 CRX si with obd1 gsr swap exhaust headers ques
Old Feb 24, 2009 | 10:22 PM
jdmek9imagex's Avatar
Default Question 91 CRX si with obd1 gsr swap exhaust headers ques
Sup guys
swapped a obd1 gsr motor into a 91 crx. going to be putting a catback skunk2 exhaust system with an OBX high flow cat. wanted to know if i can use an obd2 header because it has the o2 sensor hole. also with the stock obd1 header it has a space between the cat and header about 8-10in space. with the obb2 the header it would bolt right up. is that bad when shifting?
thanks in advance guys
Old Feb 24, 2009 | 10:56 PM
ZC DOHC CRX's Avatar
Default Re: Question 91 CRX si with obd1 gsr swap exhaust headers ques
what i did was just get my o2 sensor welded in right before the end of the header... seems to be ok
Old Feb 24, 2009 | 11:21 PM
yeah i was thinkin about doing that. what did you put between the space gap? my buddy said to buy a steel flex pipe. he said it good when hard shifting and give the exhaust movement and less vibration
Old Feb 25, 2009 | 08:29 AM
93formula's Avatar
the obd2 manifold will work, if you have the stock style spring loaded bolts and donut flange it will provide enough movement, depending on what mounts you use there will be little movement anyways...
Old Feb 25, 2009 | 11:07 AM
all i did was use the stock style spring loaded bolts and no flex pipe. do not have a problem at all
Old Feb 25, 2009 | 10:34 PM
Thanks for the info. debating if i should get the flex pipe with the obd1 headers or get an obd2 4-1 itr header. i have all hasport mounts btw
Old Feb 25, 2009 | 10:45 PM
93formula's Avatar
the hasport mounts will make it very stiff, the itr header is a better oem design so i would go with that and use the oem spring loaded bolts and donut flange, you will be fine.
Old Feb 26, 2009 | 06:05 PM
Ok, cool thanks for the advice bro
mdrshewrote
Jun 11, 2013 01:12 AM
RidingMark
Mar 3, 2007 08:14 AM
elmalouno
Jul 18, 2004 08:55 PM
tyflip2
Jun 26, 2004 03:22 PM
tuan...
Feb 12, 2004 09:37 AM
