JUN cams w/ stock valvetrain?
did a seach but didnt find what i was looking for..i was wondering JUN has 3 different staged cams..which cams are best if you have cams gears but a stock valve train and ecu??thanks
p.s. on a JDM ITR motor in case your wondering??
Why would you spend all that $$$ on some bad *** cams only to severly limit their potential by using a stock valvetrain. What the fock are you thinking? Thats one of the stupidest questions I have heard on this mb. Save up and do it right.
thanks for the input guys
your right levi..well have some fast cars next summer..we got are work cut out for us though L0L..and for you Mr. Ewing..if you ever reply to one of my posts ill find out where you live and cut your fuc*in hands and toes so you can never type again you fool
Ok, im sorry, I didnt correctly read your post, I apoligize. Stage 1 will work w/ your valve train. Id opt for toda spec a's though.
I perfer toda b/c they have more lift and duration, thus making slightly more power. Toda spec A's Int 290/11.6 Exh 280/11.2 compared to Stage 1's Int 265/10.9 Exh 268/10.0. The info is from a SamKarp post rating cams on Clubsi. My personal opinion is Jun
Toda
Toda
Hey, didnt Mike K run stock ITR valvetrain when he did the Great Cam Test when he ran the JUNII intake cam with ITR exhaust cam? I cant remember what the redline on that set-up was, But Im pretty sure he still had stock valvetrain or Portflow with ITR outters.
HXman, whatever happened with your turbo?
I use to be known as LS(litesleeper). We met at Taco Bell once, then I never heard from ya again
Guest
Posts: n/a
in the grand scheme of it all....cams alone will not yield no more than 15hp. You may want to think about getting a lightweight flywheel (unless you have an auto), & shorter final drive to help PUT that added power to the ground.
Also, think about getting a Hondata ECU as well.
most important of all - GET IT DYNO-TUNED!!
