head gasket question
hey guys
like i said, im planning on some spring maintenance for the itr and i was planning on doing a valve adjustment as well as replacing my valve cover. should i just take this opportunity to replace the head gasket as well?
also OEM will be sufficient? or would one of those thing cosmetic gaskets be good as well?
thanks in advance
thanks in advance
If there are no signs of fatigue, don't crack the motor.
No oil leaks or coolant being burnt, don't crack the motor.
Also, I'd recommend only using a O.E./ Golden Eagle Headgasket.
I'm currently running a Cometic in my new setup but I haven't fired it up yet. (84mm itr 9:1)
thanks for the input...guess i wont touch it then. just thought of it when i was thinking of what i needed to do when i take the car out of storage
Rikaro
Feb 28, 2008 10:07 AM
