p72 and pr4 oil pump interchangeable
Old Feb 24, 2009 | 05:15 PM
qazaq's Avatar
Default p72 and pr4 oil pump interchangeable
pr4 94-95 b series oil pump interchangeable with p72 96+ oil pump?
Old Feb 24, 2009 | 05:16 PM
Jas9848's Avatar
Default Re: p72 and pr4 oil pump interchangeable
physically they bolt up the same, but the pressures are different. you need a vtec pump with a vtec head/motor
Old Feb 24, 2009 | 07:51 PM
mr.beeks's Avatar
vtec has oil squirters need extra pressure
Old Feb 24, 2009 | 11:20 PM
dc4-b20's Avatar
all B series pumps will bolt on. for LS/b20 vtec you need any VTEC oil pump, GSR, TYPE R, B16 JDM b16 JDM GSR... etc...
Old Feb 25, 2009 | 04:46 AM
qazaq's Avatar
good to know, ty
what made me stumble is different part numbers on obdI gsr and obdII gsr, both vtec. one is pr4 and newer p72. im assuming it should fit, but i already ordered p72 so i will find out soon
Old Feb 25, 2009 | 08:49 AM
seanbev24's Avatar
i think the obd2 one is a bit different cuz it uses a crank sensor, not sure if it's usable on obd1 block or not i imagine the bolt holes all line up
christmastree
Sep 20, 2011 08:04 AM
stevenDAtegra
Dec 15, 2008 07:53 AM
LBR92DA-T
Nov 12, 2003 09:16 PM
X2BOARD
Apr 16, 2002 12:26 PM
internet ay
Apr 9, 2002 06:40 PM
