h22 blox b cams harsh vtec transition???
Old Feb 24, 2009 | 04:41 PM
eg_h22's Avatar
From: Beautiful beaches, skies, and ladies. No worries(.) @ the OBX, NC
Default h22 blox b cams harsh vtec transition???
I got blox b cams in my h22 and the vtec transition is crazy harsh. Its got a nice even tone until vtec hits and with a snap of a finger at 5000rpm its crazy loud and raspy and obnoxious and just doesnt feel right. My tuner says the transition isnt right either. Anyone have any ideas what could be goin on?
A pinch in the exhaust?
A loose timing belt? (my timing belt is kinda flappy when its runnin)
Old Feb 24, 2009 | 07:46 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: h22 blox b cams harsh vtec transition???
What's the whole setup?
I'd fix your timing belt then.
Can you post up your dyno?
Old Feb 24, 2009 | 07:55 PM
1.5Slowmatic's Avatar
x2. VTEC maybe engaging at the wrong time thats the reason we ask to see the graph
Old Feb 25, 2009 | 12:55 PM
eg_h22's Avatar
I dont have the graph right off hand but the numbers were wack. 190whp and crazy low tourqe numbers.
setup is:
jdm h22
blox b cams springs and retainers
camp1320 tri-y header
2.5" exhaust (3" straight back next week)
stock bottom
68mm tb port matched plenum
Btw, after the tune and after eveyone was very dissapionted with the numbers we noticed a pinch in the exhaust that decreased from 2.5" to about a 1.5" maybe smaller
Old Feb 25, 2009 | 02:15 PM
98vtec's Avatar
moderator emeritus
setup is:
jdm h22
stock bottom
ok so fix what you know is broken.
Old Feb 25, 2009 | 02:56 PM
HdeucedeuceA's Avatar
He's going to get a 3" ran next week. Fixing it wouldn't be worth the time.
Old Feb 26, 2009 | 05:59 AM
eg_h22's Avatar
I am with a straight 3" but I was just wondering if this could be why vtec isn't right or if anyone had any other posibilities of why it would do this
Old Feb 26, 2009 | 06:05 AM
00MRSi's Avatar
Install the 3inch exhaut and dyno again
Old Feb 27, 2009 | 07:53 AM
eg_h22's Avatar
will do. Hopefully that solves the problem. I've seen these same setups make over 220 to the wheels so we'll see what happens
Old Feb 27, 2009 | 08:00 AM
can you see a chart of it at all? When VTEC engages does it dip or is it flat
Old Feb 27, 2009 | 08:26 AM
eg_h22's Avatar
To be honest I can't find the graph so that sucks.
Lets say it did dip when vtec engages, what would you suspect then?
Old Feb 27, 2009 | 08:24 PM
that its set to low, raise it up a tad and see what happens
Old Feb 28, 2009 | 12:13 PM
eg_h22's Avatar
5000 rpm shouldnt be to low should it or I guess maybe it depends on the cam?
Old Feb 28, 2009 | 12:36 PM
turboedsupe's Avatar
It can depend on many thigns. My tuner said he thought my 3" exhaust helped him turn vtec on at 4400 which he says usually you would see a power dip as described
Old Mar 1, 2009 | 02:49 PM
eg_h22's Avatar
Could you name a few of the things it could depend on?
that makes me feel alot better about the 3" exhaust solvin the problem for the most part.
Old Mar 1, 2009 | 04:02 PM
I'm going to quess that the IM, cams and header make the most difference. But even the small thinks like intake length have a big effect.
Old Mar 1, 2009 | 04:16 PM
eg_h22's Avatar
Sorry I'm a little confused about this statement. Are you saying the three things you mentioned could not be right?
Old Mar 1, 2009 | 04:19 PM
h2.4's Avatar
address all the problems you stated above first. if you still question its transition, its probibly time to move your engagement point up. if the "b" cams have a conservative primary lobe with a aggressive vtec, you might need to bring your engagement point up higher. all considering your air fuel and timing are correct.
Old Mar 1, 2009 | 04:28 PM
eg_h22's Avatar
Thanks man. Thats what I was lookin for. All these things you just described have been runnin through my head but I never really got it out bc of uncertainty due to lack of knowledge about the situation
Old Mar 1, 2009 | 09:20 PM
tagperformance's Avatar
I beleive your timing is gonna be off if your timimg belt is flappy and also the vtec should be set at 5300rpm's or higher.
Old Mar 2, 2009 | 01:30 PM
eg_h22's Avatar
Cool man. Yea I feel that way to. Thanks for the input
jdm 1080p
Apr 23, 2013 10:33 PM
Golding.racing
Feb 7, 2012 02:01 PM
asmallsol
Aug 1, 2006 06:06 AM
