My turbo teg :) intro.
Old Feb 24, 2009 | 03:44 PM
dc4-b20's Avatar
Default My turbo teg :) intro.
mods.
Head:
B16a head Ported/polished/match done by me.
5 way angle job new guides/ done by, cylinder head exchange
Comp stage 1 N/A camshafts
Head resurfaced to 20k of a inch.
Block:
b20b 84 MM stock no overbore.
Manley 9:1 forged pistons. 84mm
ARP rod studs
B20VTECconverted
B18C oil pump
Race bearings from Summit racing
Turbo:
XS power A/R 50
HKS BOV
Baby mount intercooler
pieced toghter piping. (home made turbo ;] )
unknown wastegate at 8 psi. (replacing soon with a tial)
Catch can etc...
Fuel system
450 CC injectors
Walbro 255 LPH fuel pump
Brakes/Suspension
Zeal Function b6 coilovers by "Endless"
Brembo cross drilled/slotted rotors
Misc
Skunk 2 shiftknob
Apexi rad cap
Still in the process of building this motor ill update it when i get back from work with some pics.
<b> heres a snap at Fontana a few months ago when i was running it on Nitrous
<b>
will have more teasers later... enjoy!
Old Feb 24, 2009 | 06:17 PM
teg_95's Avatar
Default Re: My turbo teg :) intro.
honestly what are your inputs on nitrous. im in a pickle on running a 75-100 shot wet zex kit or turbo.
Old Feb 24, 2009 | 07:41 PM
418whpturboD's Avatar
right on man.. good luck with the build..
Old Feb 24, 2009 | 08:52 PM
Schister66's Avatar
Man U FTW
I'm always "that guy" and i'll apologize for it now...but i'm not a fan of building B20 engines since the stock sleeves are known to be the weakest of all B series sleeves. You would have been better off running an LS or GSR bottom end. As for the turbo setup, it seems ok. If the XS Power turbo is holding together, consider yourself lucky. I hope that trend contines. Also, for having a built engine, you're not exactly pushing it very hard. I'm basing that on your rather small turbo choice and the 450cc injectors. With the power you're limited to, you could have stuck with a stock bottom end and been just fine.
Having said all that, i'm sure it's a fun car. It's a lot more fun to drive than my car currently...which is sitting in my buddy's shop and has been for a good while. Don't take what i said previously as a slam, just more or less constructive criticism...you have to expect to take some heat here
Old Feb 24, 2009 | 10:20 PM
dc4-b20's Avatar
i ran a 75 shot and it was completly pointless the car hardly budged its really hard to notice anything around 75 shot. NOS is good for 1 time use or only at track use. WHY you might ask because its expensive, think about it nitrous is 5 dollars per pound so to fill a 10 pound is 50 bucks and it does not last more then 5-6 pass's at the 1/4 track. SO OVER ALL for daily driving nitrous is very pointless, waste of money, and weak unless you do a huge shot. and the 50 + 50 + 50 + 50 + 50 add up and u notice you could of bought a turbo kit. my advice on nitrous being that i have been there, and its a NO. but good luck on whatever you decide i hope you the best
Old Feb 24, 2009 | 10:23 PM
dc4-b20's Avatar
no hard feelings but you really believe what every kid on forum says about weak sleeves on a b20 then go ahead and believe it. but just ask your self if b20 was as weak as you think it is, then why did honda create the b21 motor? they pushed it with that bore and stopped at the b21. so my criticism to you is go and build motors and run them (by that i mean OWN a b20 ) then when the sleeves melt take a picture and send it to me. infact since you wanna talk about b20 sleeves melting why dont you show me some pics, there should be plenty right? go and dig up as many as you can and come rub it in my face.
edit - and also just wanted to add in, im wondering if you even knew a b21 existed? becuase you said b20 has the weakest sleeves of all B series, hmmmm that sounds a bit weird, the same b series block but bored to 2.1 has stronger sleeve then a 2.0 :]
Old Feb 25, 2009 | 05:49 AM
teg_95's Avatar
well i think u just changed my mind. thanks man. keep up the good work...
Old Feb 25, 2009 | 05:55 AM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Im a B20 fan myself, but have never seen a B21- details?
Old Feb 25, 2009 | 09:21 AM
be18see1's Avatar
I think the B21 came in the Prelude, don't know exactly what model year but I'm fairly certain it was late 80's into the early 90's. It is a different casting than the B20 we are familiar with in the CRV and is, for the most part, worthless. This is off the top of my head so feel free to correct me.
confirmed: http://en.wikipedia.org/wiki/Honda_B20A_engine#B21A
Old Feb 25, 2009 | 10:29 AM
ALLxMOTOR EG's Avatar
Vietnamese!
How much WHP and TQ you putting down?
Old Feb 25, 2009 | 11:35 AM
dc4-b20's Avatar
The motor is still just a bare block im waiting to pick up my head today the machine shop as assembling it for me because i dont have the proper spring compressor + they are doing the valve job because i dont have the special gridning tools (laping the valves didnt work )
but I will be aiming roughly 320 whp at 14 psi thats what my goal is but ofcourse that all depends on the tuner its hard to predict now days your hp before your car hits the dyno but i definetly will be sure to let everyone know the #'s when its all done
Old Feb 25, 2009 | 11:40 AM
dc4-b20's Avatar
also the b21 is just a B series block same as all other other b20's just bore'd out.
The b21 came in early preludes, i know this cuz im a motor junky most people that even know that theres actaully a DOHC D series and im not talking about the engine code of a DOHC ZC.
anyways just to add ontop of my b20 comments earlier, if the B20 was such a "fail' and "weak sleeves" then why did honda make mass production of those motors?
i hope you know it goes from b20b/b20a all the way thru a9
Old Feb 25, 2009 | 12:05 PM
lifesforlivin's Avatar
New User
looks good dude. nice car
Old Feb 25, 2009 | 04:52 PM
dc4-b20's Avatar
thanks everyone, lets see what yall have show me
Old Feb 25, 2009 | 05:35 PM
Schister66's Avatar
Man U FTW
There is already an Integra Picture thread. That page should serve as your intro as well. We try to keep the rest of the Integra forum to a strictly technical forum...or such is the hope
https://honda-tech.com/forums/acura-integra-6/official-integra-picture-thread%2A%2A-no-commentary-read-rules-before-posting-%2A%2A-2241968/
dan ek9
Jul 2, 2010 07:33 PM
Got_EF8
Aug 3, 2009 10:04 PM
Jay.D.Em!
Mar 18, 2007 02:34 PM
chidoks
Aug 21, 2006 07:35 PM
snailpower
Dec 7, 2005 09:18 AM
