Turbo Vic's Recovered theft 98 gsr sedan resurrection. lsvtec inside
Old Feb 24, 2009 | 02:20 PM
SQ is the SQUAD's Avatar
Default Turbo Vic's Recovered theft 98 gsr sedan resurrection. lsvtec inside
ok. so i brought this 98 gsr sedan shell of craigslist for $800. truthfully, i am very happy with it, but it did look alot better in the pictures. the kid i brought it from had the car for maybe about 800 miles. he brought it, blew the motor, put another motor in it and within 3 weeks i got stolen and stripped. the title was branded prior theft prior to this so this wasent the first time this integra got stolen.
i was going to throw a p8r b20 in it, buy came accross a great deal on a obd1 b18b on craigslist for $300, but it had an autotranny on it.
the next nite i found a bare b16a head on craigslist for $100. so decided to go lsvtec.
as of right now there is no motor in the car, i been fixing the little things first. i nistalled my hids, ran the system wires and started my alarm install. while i have the seats and carpet out ill take them to get steam cleaned.
so here it is
Old Feb 24, 2009 | 02:24 PM
Default Re: Turbo Vic's Recovered theft 98 gsr sedan resurrection. lsvtec inside
so i pulled out the seats and carpet to run my system wires, pre wire my alarm and start cleanig the car. i found some mold under the drivers seat
heres the auto b18b
i pulled the auto tranny off today.
i ordered one of the cheap ebay clutches. i had good luck with them before, and dont plan on beating this car too much. i basically got the 4dr because ill be having my first child in june.
Old Feb 24, 2009 | 02:29 PM
so the b16a head i got was totally disassembled. i originally though i was buying a bare head, but it looks like the kid actually had every thing except the cams, distributor and vtec solenoid
Old Feb 24, 2009 | 02:34 PM
94LS_allmota's Avatar
nice.....but wats the point of installing hids and putting a system if u cant drive it....maybe invest the money to get it running and then the goodies.........my 2cents
Old Feb 24, 2009 | 02:50 PM
parts i already had from my ef that i parted out smarty pants.
Old Feb 24, 2009 | 04:36 PM
redpreludesi's Avatar
hehe this is why i belong to nwp to much negative comments on here for me... its his car his money he can do what he wants unless you feel like paying for all the stuff 94ls?!
i think your coming along fine bro keep it up
Old Feb 24, 2009 | 05:35 PM
quick question. will a half shaft from an automatic transmission fit on my manual tranny swap?
Old Feb 24, 2009 | 05:48 PM
Brice.Hayden's Avatar
i doubt it, but it might. i would just get the correct one.
check the part numbers
www.oemacuraparts.com
Old Feb 24, 2009 | 06:10 PM
AnT|228's Avatar
Nice! Keep up the good work!!
Old Feb 24, 2009 | 10:21 PM
EK_EG_DC's Avatar
Nice going LS Vtec. it good how your setting everything up and dont have to deal with it when you have everything inside. this is how i do my work on my cars too so keep up the good work. its a good deal you got the car and B16 head for.
Old Feb 25, 2009 | 03:41 AM
yeah i am only trying to do every thing once. while the carpet and seats are out i am going to have them detailed.
Old Feb 25, 2009 | 11:01 AM
OldSkoolDa91's Avatar
nice. i love 4 door integras. i'm in for the build!
Old Feb 25, 2009 | 08:41 PM
bonstokLS's Avatar
In it for this build up!!!
Old Feb 26, 2009 | 04:34 AM
hopefully either today or tommarow i can meet this guy for a gsr tranny. he said the rear mount bolt broke off in the case, $200 i think i can deal with that. worse comes to worse i;l get a new case.
Old Feb 26, 2009 | 06:02 AM
yeah thats not a bad deal at all.
Old Feb 28, 2009 | 06:29 PM
had a long day at the junkyard today. i got a new ignition with key, the plastic cover, and the trunk silinoid for $20. then i went to another junkyard and got 1 flywheel bolt and all the pressure plate bolts of a da integra
my ebay clutch kit came in. so now i got all the bolts i needed so i threw it on the block
Old Feb 28, 2009 | 08:15 PM
numberone's Avatar
Looking good bro, keep up the good work.
Old Feb 28, 2009 | 08:22 PM
i picked up a gsr tranny tonite for $200. the bottom rear bolt hole had a bolt broken into it and the top rear hole was broken off. shouldn't be too hard to fix
Old Mar 1, 2009 | 06:16 AM
so i came across a deal for some of these type s rims.
i figured they would be nice and something different on a db. especially after i send a week and polish them up
so i made a thread asking about redrilling stock db hubs for a 5.114 bolt pattern and got flamed by not only mods, but so super tyte jdm people. they dont understand why i woyldent want to putt off my brand new suspension to throw away 1000 on used type r suspension. so if i have time this week i am going to grab a spare hub from the junkyard and see how well it taps out. there was 2 accord ex wagons when i went yesterday that had 11" brakes, so ill snag some calipers and the brackets. abd ill atlease test fit one side to see how everythnig works out. my only concern was about where the studs are pressed into the hub. i gotta make sure they are tight. i was thinking maybe lubing (or unlubing) the groved part of the stud with some jbweld to seize in inplace once its pressed into the hub. on maybe pressing it in and throwing tac welds on the back. if anyone has tried anything like this throw me some ideas
Old Mar 1, 2009 | 12:17 PM
vladd's Avatar
^^ Dogginator gave you a good explanation on why redrilling the hubs wouldn't work. also, you'll need to change the door locks to fit the new key that you got with the ignition. you can just take the locks out of the doors and have a locksmith change them.
Old Mar 1, 2009 | 12:24 PM
I wouldnt put 17" OEM wheels on an 4dr integra it won't look right. jsut invest in a nice set of 15 or 16" wheels. you'll be better off.
nice pick up at the junkyard
Old Mar 1, 2009 | 01:16 PM
eh, i wouldnt worry that much about changing the door locks. he'll just have 2 dif. keys. oh well.
Old Mar 1, 2009 | 02:58 PM
i couuld of got the door cylenders for free, however i am going to put rear dors handles on the front and eliminate the key holes, along with the trunk one. so the only key i will need is the ignition. the arlarm/power door lock run off a back up battery so i am not worried about that. in the case all other power does die i have a way of supplying a 12v power source without getting under the hood. i just can give away all my alarm secrates
Old Mar 1, 2009 | 06:47 PM
good deal
Old Mar 2, 2009 | 05:42 AM
delbert's Avatar
nice build so far
