GSR into 99 Civic SI
K so im doing a motor swap frrom a B16 to a GSR...i just had some questions on whether i needed any pieces or parts from the b16 to put in the b18..if u can i would deeply appreciate the answers..thANKS
lol..i was going to but i got an offer for the b16 already and i am in need of some money for spring break...but the GSR came with mounts already and a harness and everything else besides the axles which i was going to keep anyways...so i don really need anything else from the b16 besides that named above??
I am using a gsr OBD1 P72 ecu with a obd2 to obd1 converter harness. My question is if I do get an 00 si harness will I need to modify it in order for it to work with the gsr manifold (since the the gsr and b16 have different manifolds), or will it be a simple plug and play??
i think it would be plug and play unless the b16 has less sensors then the gsr then you'll need to wire them but im not to sure either...most likely it is plug and play
Oh I'm looking to get an si harness cause thats what I was told will work with this swap. So I'm just trying to make sure thats the right harness needed for this type of swap.
i wasn't talking to you thread jacker LOL
99 civic Si came with a b16a not a b16b. the short block is different.
again, to the OP...just go B20VTEC
kpop
Jul 16, 2006 11:47 AM
nexgen91
Mar 7, 2006 07:27 AM
