ZERG industries headgasket any good??
Looking at getting this haed gasket for my build and was wondering has any one used it before or have any info on it? Heres the link to it:
http://www.streetlightz.com/Zerg-Ind...sket-P343.aspx
you can pull the center layer from an OEM and do the same thing. the tried and trued is cometic for a thicker gasket and OEM for a thinner. pull the center layer if you want to use a 2 layer
I thought it was discussed somewhere that you actually want to keep the center portion and pull the upper or lower to keep the coolant flow characteristics the same. I know that many guys have gotten away with removing the center section but I believe keeping the center is better.
It's cheap and easy if you're doing a new swap. It's good practice to pull the head and put a new gasket in there and that's what I did with my B16 in the day. :D
So many people misunderstand the concept of using a single or 2 layered head gasket. You don't use them to give you a bump in compression typically, you use them to FINE TUNE your final compression number to where you want it. If you build a block and cc a head that comes out to 11.3:1 and you want 11.5:1, it makes more sense to use a thinner gasket than mill the head or deck the block any further.
A 2 layer gasket won't bump your compression by .4, a single layer would. You'd have to cc the head to have a better idea of where you'd be at. Their product description is wrong.
what setup do you have i might be able to estimate where your compression is now and where it will be after the 2-layer gasket and your probably gonna get like .2 i think
heel_touge
Sep 11, 2002 09:06 PM
