M2B4 lsd tranny help...
ok, so I traded this guy for this tranny about 2 years ago and I just now got my car running. Well we havent driven the car yet but had it up on jack stands taking it through some gears. well it runs at 3k rpm at 50 mph in 5th gear, is this normal? the rpm seems awful high. also my dad said he noticed that the wheels did not turn independently of one another, kinf of like the transmission was acting as a straight axle? is this normal? He said that the final drive must not be stock from honda and that the tranny has been opened up before? any help it greatly appreciated.
Cory
Cory
If you have LSD the wheels will turn together when on jack stands. LSD makes it so that one drive wheel will not turn more that 10% faster than the other drive wheel- this is when there is a load on the drive train if there is no load(like when on jack stands) the wheels will turn together. As far as the rpm and speed I would not look that far into that until you try it on the street.
BTW 10% is an estimate
that is pretty close to the 4th gen tranny with the 4.64FD, but the M2B4 is not compatable with aftermarket final drives, so unless its custom, i'm not sure, you're sure its an M2B4?
and speed/RPM is the same in the air or on the ground
im sure its an m2b4 case because of the stamp. so I am going to assume that its an m2b4 FD along with all the other gears. My dad said when on jack stands, at 70 mph in 5th gear it revs at 3700 RPM. that seems normal if you ask me. He is gonna drive it on the road and see how it does. Anymore ideas is great
yeah im not sure the exect rpms sence mines been in storage but my m2a4 is at 3k at 50 witch is the same as yours so everything sounds fine. 70 is about 4 witch is also what u have.
we both have jdm transmissions you just have a lsd and i dont, but both should have the same gears
You need to stop going from thread to thread and posting your crappy misinformation framed as facts.
Cory, you're probably fine here, just get it on the road and see what you get. The rpms sound about right.
What is incorrect about what I was saying
A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
There is that better?
gearing is gearing dude, any RPM through whatever gearing is going to be the same output at the wheels. i think you might be thinking that since it requires less load to get to that speed, that it will be different, but it is not. hate to break it to you, but you're wrong. again
its irrelevant, the only speed he knows, and the ONLY speed that anything modified in the transmissions will give him is at the VSS, which goes to the speedometer.
yes, wheels and tires affect gearing, but that will not alter your VSS reading
The only thing I was trying to point out is that it could be different when on the road. If I offended you by doing this I apologize.
it won't be different on the road, his speedometer will read the same, so unless he is driving by radar traps to check his speed, his speed will be the same for all intents and purposes
ok, so the RPMs seem to be about right. But what about the wheels turning independently of one another? Is this because the car was on jack stands? If im not mistaken when turning, the inside tire requires less rotations correct? And the LSD is what allows one tire to turn less than another? I really know nothing about transmissions.
A "2 way" LSD as you're speaking of it means that the axles can be locked together both on acceleration and deceleration.
The nature of an LSD is the following: in normal driving conditions it is unlocked, and the axles are free to spin independently. Cory, check this by holding one wheel still and spinning the other.
When the LSD senses slip (when one wheel is spinning a lot faster than the other), it locks the two axles together so that they spin at the same speed. This locking is very pronounced in honda LSDs, it used to jerk the dash in my car at times. If turning and slipping, the LSD engaging can cause more slip if you're not ready for it. In that case you're best off pointing at the turn exit and praying.
so...my dad got the car running really good. But he says the car jerks really bad in turns. He thinks the differential might be bad but from what I read this is normal in Hondas? So what do I do now? He said it only jerks and shakes in the middle of turns.
ironchef25
Feb 19, 2004 10:35 AM
axle, axles, dc5, decelerate, drive, faster, honda, jerking, lsd, m2b4, prelude, slipping, transmission, transmissions, wiki
