B16 b18
What does this 220 whp build consist of? What do you expect the total output will be with the bolt ons?
im using an b18a block w/ b16a head the major parts are to include-
golden eagle vtec kit/h-beam rods, 11-1 CP pistons,ARP head studs/rod bolts.
bolt ons wil include MSD ignition/coil/cap hytecheaders, skunk 2 pro series intake manifold, password JDM CF intake w/dry filtrer and a test pipe w/ custom exhaust.
It'll all be controled by a chrome tuned ECU. Havn't decided on cams or springs yet. check out the pics of my build they should be posted in the next few days.
How the hell are you projecting 220whp?
havn't been online to reply. To all the comments my motor is being built at street performance in VA. I have a ported b16 head and im going to be runing the ITR cams for the stronger v tec lobe. My stroke is increased by the eagle h beam rods and even more with the domed hicomp pistons. Ive looked to boost as an option for more power but i cant run more than 5 psi with the all ready high compression. Im basing my HP off a simular build all ready at the shop making more power.
so you can increase stroke by getting longer rods?? interesting. good thing a shop is building your motor rather then yourself. A little suggestion, decide what you want to do, all motor, or boost. The two really don't mix well.
havn't been online to reply. To all the comments my motor is being built at street performance in va. I have a ported b16 head and im going to be runing the itr cams for the stronger v tec lobe. My stroke is increased by the eagle h beam rods and even more with the domed hicomp pistons. Ive looked to boost as an option for more power but i cant run more than 5 psi with the all ready high compression. Im basing my hp off a simular build all ready at the shop making more power.
I hope you realize you're in the all motor forum....it's not the place to try and BS people. ITR cams are hardly the choice for a "projected" 220whp build. Explain to us how your Eagle rods increased your stroke? better yet, explain how you also increased it with domed hi-comp pistons? You say you can't run more than 5 psi with the "already high compression" ...do you call 11:1 compression high? There is no way a similar build at the shop is making more power than the projected 220whp, unless someone is on some serious drugs or is actually running something larger than a b18.
I doubt that similar build is making 220whp with ITR cams in an NA build.
