Are front strut mounts same as rear?
Old Feb 23, 2009 | 11:03 PM
Gregmatic's Avatar
Default Are front strut mounts same as rear?
Haven't gotten to look in the rear and search yielded little info. Hoping I can use the front mounts to build the rear struts while off the vehicle. This will save downtime and make it a swap-out-swap-in affair.
Old Feb 23, 2009 | 11:42 PM
Tyson's Avatar
Default Re: Are front strut mounts same as rear?
i really have no clue what part of the shock youre asking about.
the only thing interchangeable is the top hat mount. but theyre not the same either, just slightly different. the rears have an oval oring.
the shocks are completely different front and rear.
Old Feb 23, 2009 | 11:45 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Front and rear are totally different.
Old Feb 24, 2009 | 06:04 AM
soodominican's Avatar
i think hes talking about the pillow ball mounts
Old Oct 10, 2022 | 05:05 PM
philrad432's Avatar
So? Any luck on this? I'm currently going through the same thing.
Old Oct 10, 2022 | 11:44 PM
Tyson's Avatar
If you're asking about the top of the struts, this information is fact.
The oring in the rear top hat is because it "seals" the inside of cabin from outside, technically.
carracr625
Suspension & Brakes
Mar 21, 2011 09:05 AM
Takumi Fujiwara
May 20, 2005 02:51 AM
TypeR 1159
Jul 5, 2001 05:42 AM
