1990 accord 30PSI on cylinder 3
Old Feb 23, 2009 | 05:56 PM
GreyGoose11's Avatar
New User
Default 1990 accord 30PSI on cylinder 3
My accord wasn't firing on cylinder 3. so i replaced the plugs and wires.
it has a brand new distributor on it. i checked spark to the cylinder and
it was good. Finally i pressure tested the cylinder and it only showed 30psi.
I also checked cylinder 2 and that read a little over 150 psi.
I'm going to pull the valve cover off tomorrow to check the valves.
somebody told me it could be a blown head gasket.
anything else i should check out on the motor that could cause this?
Old Feb 23, 2009 | 06:00 PM
BlUAc's Avatar
Default Re: 1990 accord 30PSI on cylinder 3
stuck piston rings also do u have any oil in water or vice versa, clear sign head gasket. how bout cylinders 1 an 4. it may b valves sorry man
HeresOtis
Nov 10, 2017 01:21 PM
gimphand
Oct 11, 2013 06:12 AM
2kblueintegra
Sep 15, 2010 10:24 AM
BROKE.eg
Oct 28, 2005 07:14 PM
