Would any b series axles fit an ef??
hey i have a b seris swap on my ef and it makes a wierd noise and shakes a lot!
people tell me it could be my axles! so would any fit an ef or do i have to get sum custom ones?
Loose lugnuts can cause a wheel to shake if they are not tight. Easy way to tell what the problem is, jack up the front of the car... place one hand on the top of the tire by the fender and the other on the bottom, does the wheel clunk up and down? If so, bad upper ball joint... If you put your hands on either side of the tire and move it...does it? If so you have a bad tie rod end.
