...GT30 / S2000 build...
copied from my post in the Forced Induction section
What started out as a planned "simple" t28 GT2871 setup with 350whp in mind turned into a custom setup based on a GT30 with about 400-450whp in mind. The result of many conversations with Tony from T1 Race Development.... thanks Tony (I think
Anyway, here's the car as it sat last year...
And how it sits now...
And here's some of the goods that came from T1...
Flange and some expensive *** clamps...
Walbro 255 and Omni 4 bar map sensor...
Tial 44mm gate with 10psi spring...
Bosch / T1 / Injector Dynamics 1000cc's (didn't end up using the adapters)
Here's a jig I made to make a collector...
)!Anyway, here's the car as it sat last year...
Some tubing for the mani...
After some frustration and wasting some expensive tubing my friend Fathouse recommended using PVC to practice. $.50/ft vs. $16/ft.... Thanks house!
20 degree cut on the left, 15 degree on the right...
15 degree, what I ended up using...
2nd times a charm...
Ghetto backpurge...
This part was a pain!
Done!
Ghetto backpurge...
Done!
Well after some frustration and serious doubt I finally got the first runner done. I think my collector is a little long but looks like I'm going to be able to make it work.
The rest of the runners should go smoothly but I suspect 'pain in the asses' part 1 and 2 will be wastegate placement and the downpipe build. Stay tuned...
Got the #2 runner fitted up tonight. Pulled the #3 runner off to weld it up. Added some braces since I couldn't really jig it with the Vband. Also got the elbow off of the collector for the #1 runner, going to put one on the collector for the #4 runner as well before I put the #3 back on. Going to build the remainder once I get the 2 centers done, it's hard enough just keeping those 2 lined up lol!
Thanks guys!
Not really but I know it looks like it lol!
Got a little farther yesterday, almost finished up welding up the two center runners until the threads in my torch head galled up and stripped out. Got to get a tap monday
Bolted to a 5/8" piece of aluminum for a heat sink...
Every once in a while I get a good one
Inlinepro 600hp i/c courtesy of my friend Carey (bosstedh22a). Yes I know it's upside down, fits higher that way and I'm not going to notch the frame rails for it!
