valve adjustment questions...
Can the engine get damaged from not receiving a valve adjustment? I havent done one w/ my motor, im not sure if i need to do it or not, what are the signs? I heard its best to do it when the engine is cold instead of hot. Does anyone know the valve adjustment specs for a 96 JDM ITR motor?
thanks.
thanks.
if the valve clearances get extremely out of spec, yes. it can cause damage, much like if you adjust them improperly.
like many other required maintanences, you should do it if you like your car
[Modified by Soup ****, 3:18 PM 8/10/2002]
here is a good site to use as a guide if it is your first time.
http://www.c-speedracing.com/howto/v...lveadjust.html
hope this helps you!
Thomas
