will a jdm type r coupe front fir on a 98 gsr sedan?
Old Feb 23, 2009 | 10:46 AM
SQ is the SQUAD's Avatar
Default will a jdm type r coupe front fir on a 98 gsr sedan?
brought a 98 gsr sedan recovered theft. thinknig about throwing a itr front on it. i did see one db8 itr front on ebay but there are two dc itr fronts locally (boston ma, not that common). just wondering if the coupe front fits the sedan
Old Feb 23, 2009 | 12:16 PM
shy_lee85's Avatar
Default Re: will a jdm type r coupe front fir on a 98 gsr sedan?
yes it does...4 door or 2 door..don't matter..the front end fits...just be sure to get the radiator support for the front end..
Old Feb 23, 2009 | 12:31 PM
dvs94Teg's Avatar
From: NORCAL Salinas Valley to Monterey Bay Area 831 CA
X2. The radiator support is the key to making this conversion work.
Old Feb 23, 2009 | 12:36 PM
dmpd_ef's Avatar
x2 on waht they said^^^
also try to pick up a 90-93 integra hood latch in case your radiator support doesnt come w one
Old Feb 23, 2009 | 01:17 PM
good looks peep. i read a few threads where they talked about the da or 97 accord hood wires. i know the radiator support is key. its just mainly the upper part correct?
i seen quite a few conversions online but shipping to boston is a killer
Old Feb 23, 2009 | 01:32 PM
5GVTEC's Avatar
some people swap the whole thing, and some people are just doing the "T" bar, the top and center section
Old Feb 23, 2009 | 02:45 PM
HONDRETTI's Avatar
that **** will fit on any DC. even on a DA, EK, EG, or an accord station wagon. go to b20 they'll tell you.
Old Feb 26, 2009 | 08:50 AM
lsvteg11's Avatar
lolz obviously you need the radiator support. How else would you expect you aligne the bumper, lights and hood??
Old Feb 26, 2009 | 10:07 AM
JDM 98 GSR's Avatar
yes it will. and its looks sick on a 4 door not to many people do it atleast not as many as you seen on 2dr
Old Feb 26, 2009 | 11:10 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Yes.
Old Feb 26, 2009 | 11:30 AM
shy_lee85's Avatar
it's better to have the radiator support then the T Bar..don't go the cheap route...do it the right way..
Old Feb 26, 2009 | 11:57 AM
JDMDALOUIE's Avatar
Theres a 4 door Integra over here and it has ITR front and looks really clean. I don't get why a lot of people don't do that.
Old Feb 26, 2009 | 12:33 PM
dvs94Teg's Avatar
Doing just the "T bar" alone isnt the cheap route of doing the swap. Its easier and more practical doing it this way. only difference is the "T". Undo the spot welds from the udsm rad support with a drill and just weld on the "T bar" in its place. I believe there are a total of only six factory spot welds that are holding the usdm rad support. two at each corner where the rad support meets the fender support and another two at the very bottom of the core support at the center. Id post some pics if i had some. this is the procedure i took to get mine done and is been holding up great! no sag what so ever. everything is lined up perfectly. Ur also going to need a DA hood latch with the cable. ( dont worry, the hood latch is a perfect fit for the t bar as well.
Old Feb 26, 2009 | 12:34 PM
dvs94Teg's Avatar
pm me if any additional info is needed.
Old Feb 26, 2009 | 07:28 PM
singlecamsaver's Avatar
mine:
Old Feb 27, 2009 | 06:07 AM
JDM 98 GSR's Avatar
its not only the T-bar. you cant just stick the T-bar on it and be done. there are i think 5 brackets that are welded on the jdm rad support that are for the headlights unless you just want to stick 2 bolts in the top and thats it. and also when just using the T-bar you have to cut a small amount off the side of the USDM rad support on each corner by the headlights so the JDM lights will go all the way in. you dont have to cut much off if you put the two supports next to eachother you can see there is more to change over to your USDM support then just the T- bar but im very picky with things
Old Feb 27, 2009 | 07:25 PM
dvs94Teg's Avatar
I did mine the way i stated. But one thing i forgot to mention was cutting out the sides to allow the jdm headlight all the way thru just as you pointed out. My conversion came out flawless, its just a matter of getting it painted to finish things off. good eye tho.
Old Feb 27, 2009 | 08:23 PM
jdmjoka's Avatar
DB squad #282
bump fellow db owner and there sexy with those front's
B16Civic93
Mid-Atlantic (Sales)
Aug 27, 2009 02:31 PM
B00STeD
Aug 30, 2002 04:35 PM
