Couple questions on the b series swap into a CRX
Old Feb 23, 2009 | 10:40 AM
streetsold6teeny8's Avatar
Default Couple questions on the b series swap into a CRX
A full gsr swap from an eg......... will the axles fit my 89 crx with the swap??
Also Will i need a rear tranny bracket ( i know I need the mount)or can i use the one on the eg
Also will the shift linkage work or will i need one from hasport.
Thanks
Old Feb 27, 2009 | 09:24 AM
MassScene's Avatar
Default Re: Couple questions on the b series swap into a CRX
GS-R swap works fine...
Axles work fine..just use the same intermediate shaft
You need an 88-91 Jdm B16 rear bracket or any pre-94 LS rear bracket
Drivers side mount bracket is the same answer as above ^^^^
Shift Linkage You either should use Hasport 88-91 B-Series ...Or u can cut + weld which i dont really recommend if you have the $150 to buy it new.
88_hatch_ls
Mar 2, 2012 12:33 PM
streetsold6teeny8
Mar 25, 2009 07:41 PM
streetsold6teeny8
Feb 23, 2009 05:45 PM
pcguy760
Jun 8, 2006 10:20 PM
Se-rv-Tak
Nov 29, 2003 11:59 AM
