Alum Mig "Kit"
Old Feb 23, 2009 | 07:36 AM
ExVtec's Avatar
Default Alum Mig "Kit"
Taken from this link: http://www.lincolnelectric.com/knowl...compactmig.asp
Purchase an Aluminum Feeding Kit
Attention to feeding issues is much more critical when it comes to aluminum welding. It is highly recommended that you purchase an aluminum feeding kit, which includes the following items:
Non-metallic liner - designed to minimize the amount of friction on the wire
U-shaped drive rolls - to avoid crushing or deforming the soft aluminum wire. These drive rolls do not shave the wire like V-groove drive rolls. Using V-groove drive rolls, the resulting wire shavings can clog the liner and lead to feeding problems.
Inlet and outlet guides - designed specifically to avoid wire shaving.
Contact tips - as compared to those used for the same diameter of steel wire electrode, contact tips for aluminum have larger diameter holes, since as aluminum heats up, it expands more than steel. Therefore, contact tips for aluminum applications are sized small enough to maintain good electrical contact, but large enough to allow for expansion.
My question is...where can I purchase the "kit" from? I haven't seen it sold anywhere local?
Thanks.
Old Feb 23, 2009 | 08:04 AM
david@didrace.com's Avatar
Default Re: Alum Mig "Kit"
Thanks.
I have a used aluminum spool gun kit upstairs if you're interested. I can pm you some pictures if you want.
Old Feb 23, 2009 | 05:33 PM
ExVtec's Avatar
Compatible with my welder?
If the price is right, and it's in good shape....shoot me a pm.
Thanks
Old Feb 24, 2009 | 07:27 AM
Tjabo's Avatar
I tried one of those kits with a little Lincoln mig, and man was that a pain! ! ! Bad enough to feed the wire properly with a spool gun.
Old Feb 24, 2009 | 08:24 AM
jewjew bean's Avatar
I bought my alluminum welding kit on ebay. although I too had bad luck with it
Old Feb 24, 2009 | 01:24 PM
punkinbeck's Avatar
its tough welding aluminum mig without a spool gun in general. It can be done but you'll be spending a lot of time pulling the wire out and putting it back through. Even with minimal tension.. Once the wire burns back into the tip the driverolls usually keep pushing the wire and break it.
twilightprotege
Welding / Fabrication
May 22, 2006 04:52 PM
supercreed2002
Mar 15, 2006 09:45 AM
