check engine light on deceleration
Old Feb 23, 2009 | 06:24 AM
oilspot's Avatar
Default check engine light on deceleration
Engine is a bone stock d16a6 (for now). This isn't happening all the time, usually once a day.
When I'm coming to a stop, usually after a downshift, with the throttle full shut, I get a check engine light. I get it more often when I have been driving the car a suspended higher rpms (i.e. highway driving).
any ideas?
Old Feb 23, 2009 | 06:42 AM
4drEF's Avatar
Keyboard Humorist
Default Re: check engine light on deceleration
what code are you getting on the ECU?
Old Feb 23, 2009 | 06:59 AM
shaggyeg6si's Avatar
Sounds like your engine is going from closed loop to open loop and looking for a sensor that's either failing, going to fail, or is not plugged in. I suspect the O2 sensor.
Old Feb 23, 2009 | 08:38 AM
89s1's Avatar
telling us you have a check engine light but not telling us what code its throwing is about as useful as putting shingles on a ham sandwich
Old Feb 24, 2009 | 09:05 AM
drift4agze's Avatar
once you get the cel. if you turn the car off. will it start? if not then i suspect the fuel pump is crapping out. i had the same ****? but yeah, i would run the code.
Old Feb 24, 2009 | 10:16 AM
SIred91's Avatar
Rainman
98dxkoupe
Oct 2, 2018 04:32 PM
ryanminer
Oct 17, 2008 08:52 AM
patpeery
Apr 4, 2008 02:40 PM
gimmerexpwr
Feb 20, 2002 11:15 PM
