Installing blox rear LCA's on 1996 cx
In theory its just remove the bolts install new LCA, done. In practice its more like break off 3 bolts then cut them off and try to remove the threaded piece stuck in the welded nut. Use an impact wrench if you can.
and about a can of pb blaster...i could literally watch the rust fall of when i put springs on my hatch. my coupe wasnt bad...the hatch on the other hand was horrible.
like wd-40...but better. it is a rust penetration solvent thing...lol it eats rust off bolts and they are alot easier to break loose when you use it.
Manolo
Suspension & Brakes
May 12, 2006 11:36 AM
