obd1 code 9
Old Feb 22, 2009 | 08:58 PM
Tensa_Zangetsu's Avatar
Default obd1 code 9
Hey i just recenttly got this code and i research about it which is related to the distributor. So i borrow a oem distributor from a friend that has no CEL and tried it on my car n it still throws the same code!?!?
Additional info:
-91 crx dx with b20b swap
Old Feb 23, 2009 | 06:41 AM
George777's Avatar
Default Re: obd1 code 9
Did you reset the ECU before you tried the other dizzy?
Old Feb 23, 2009 | 09:21 AM
yup. did it twice too
Old Feb 28, 2009 | 04:13 PM
need help plz!
Old Feb 28, 2009 | 04:28 PM
93formula's Avatar
did you get this code after the swap? are you running it on obd0 or obd1? check your wiring/ecu. usually its either the dist, the wiring or ecu.
Old Feb 28, 2009 | 04:38 PM
yea i got the code after a b20b swap onto my crx. Im running obd1. I have checked my rewires like twice and yet no luck.Also swap with like 2-3 dizzies in good condition.
Old Feb 28, 2009 | 04:55 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Well if you are swapping out distributors with no luck. You have double checked your rewire.
Then double check the wires themselves. Maybe there is a bad connection in the connectors. Either that or maybe a wire is split or not engaging in the connector.
You should do more than just rely on somebody to give you the solving answer; we can just give suggestions not check for you.
Grab a multi-meter/ continuity tester and check all the swapped wires.
Old Feb 28, 2009 | 04:56 PM
93formula's Avatar
yup its gotta be wiring, check and double check your pinouts etc.
Old Feb 28, 2009 | 05:12 PM
yup did that today. spent about an hour with the multi-meter/contunity tester. I did come up the conclusion that it couldd be the connector since i had problem with it once.
88efsedanlx
Dec 10, 2011 05:40 PM
JustAnotherRex
17
Jul 9, 2007 04:15 PM
tgh22a
11
Apr 17, 2006 03:56 PM
gutted
24
Oct 5, 2005 08:11 AM
grlracer97
Aug 22, 2005 10:35 PM
