idle problem
Old Feb 22, 2009 | 08:56 PM
sevenfc's Avatar
Default idle problem
i just recently got my lsv using obd2 ecu (si p2t)put together and is in the process of breaking in...my problem is when i start the car, the car dont seem like it wants to keep its idle...i would have to give it some gas and keep it revd up for a while and then itll stay at idle...should i just convert to obd1 and get it tuned or is it somethin else....anybody?
Old Feb 22, 2009 | 09:41 PM
sevenfc's Avatar
Default Re: idle problem
Old Feb 23, 2009 | 06:15 AM
silverekhatch88's Avatar
New User
you might need to check your IACV wiring, and yes an OBD1 computer would probably be the way to go. You can chip and OBD1 and get it tuned for your car.
Old Feb 24, 2009 | 02:55 PM
sevenfc's Avatar
would that b the reason y my start up seems like it doesnt wanna start unless i rev it...everytime i try to start it, i have to rev it to start...
Old Feb 25, 2009 | 11:25 AM
sevenfc's Avatar
anybody
Old Feb 25, 2009 | 11:32 AM
sirt_eg's Avatar
I dont recommend using the p2t ecu. Get a p28 or p72 and chip it and tune cause ls.v are homos when running it with stock ecu. I got a ls.v myself and running a chip p28 and it runs smooth.
a little more info will be great also. What car is it in. is it converted to obd1 or obd2?
Old Feb 25, 2009 | 12:01 PM
sevenfc's Avatar
its dropped in an 00ek and is still using the stock harness..only thing that was done with the wiring was the vtec wiring and rite now im throwin cel 63 which is the second o2 and i think 23 knock sensor if im correct.. its still obd2b...i hate having to start up the car and rev it for like 5 mins with my foot on the gas and wait till its warmd up...
Old Feb 25, 2009 | 12:43 PM
sevenfc's Avatar
ttt
googootim
11
May 21, 2010 10:01 PM
NA JDM GSR
14
Jan 13, 2007 04:51 PM
AzG35
Nov 29, 2005 06:06 PM
AzG35
Dec 4, 2003 12:53 PM
bananacruzier
Jul 24, 2002 09:18 PM
