Can I put all GSR (B18c) internals into a LS block?
Old Feb 22, 2009 | 07:00 PM
DA_Love's Avatar
Default Can I put all GSR (B18c) internals into a LS block?
Like title says I have a complete GSR block that has very bad damage to the bare block and I was wondering is every part capable of swapping it over to an LS B18A block? I know those little oil squiters in the piston aren't swappable but everything else to make the Ls complete to a point will it will work and drive fine? Let me know I couldn't find any good information about this.
If I do this swap over should I run a LS head built or should I run LS Vtec?
Old Feb 22, 2009 | 07:11 PM
Presidente's Avatar
Default Re: Can I put all GSR (B18c) internals into a LS block?
u wont be able to use gsr crank and the rod's all other part's should be fine
Old Feb 22, 2009 | 07:13 PM
MumBleZ_94gsR's Avatar
u could swap everything over
DA_Love's Avatar
what both of you guys are confusing me.
Old Feb 22, 2009 | 07:20 PM
Presidente's Avatar
yeah everything swap's over but i would reconmend u to use the LS rod's and the Ls crank on the LS block instead of the gsr rod's and crank
Old Feb 23, 2009 | 04:38 AM
DA_Love's Avatar
Isn't it because it will give me more power or something like that? How do I get the wrist pin to come out so I can swap the rod over to the GSR piston? I tried it but couldn't get it.
Old Feb 23, 2009 | 05:39 AM
Micha's Avatar
FAILWGN
I believe you can use a GSR crank in the LS block.
But you have to get custom rods and pistons.
Old Feb 23, 2009 | 05:44 AM
Import_spoon's Avatar
Doesn't the GSR's have something like valve clearance if I use it on the LS block right?
HondaAddict91
Engine Machining & Assembly
Oct 9, 2016 06:37 PM
victoriasamantha
Dec 27, 2007 05:17 AM
boostin4door
Feb 12, 2006 05:43 PM
mrDFWmechanic
Apr 10, 2005 03:07 PM
trucdoken
Mar 12, 2005 09:37 PM
