Lower Ball joint wont come lose HELP!
Old Feb 22, 2009 | 06:05 PM
Mindgamez's Avatar
Default Lower Ball joint wont come lose HELP!
I sawpped a tranny on my friends 91 Teg and the lower ball joint on the driver side wont come lose. I cant get the top one or the bottom one out. I tried the forks and hitting the controll arm with a sludge hammer and i cant get it lose to put the axel back in. Any suggestions on how to get it lose? (FYI I pulled the tranny with the axel in it.)
Old Feb 22, 2009 | 06:18 PM
jdmdc2boi12's Avatar
Default Re: Lower Ball joint wont come lose HELP!
mine as well just buy a ball joint removal.. will save u time
Old Feb 22, 2009 | 06:25 PM
Kuchtaboy's Avatar
4 solid hella hard wacks to the back side of the lower control arm and mine popped right out. haha
Old Feb 22, 2009 | 06:28 PM
Jimmy's Avatar
Global Moderator
Use a 5lb hammer and give it a few whacks.. will most likely work.
If you have a 1/2 craftsman ratchet.. that will work too.
Check the [faq] always
https://honda-tech.com/forums/acura-integra-6/popping-front-lower-balljoints-other-random-observations-887859/
Old Feb 22, 2009 | 11:29 PM
TheHypnotic's Avatar
I used to use forks and weighted hammers. I always ended up tearing the boot or damaging the threads. So if you're not changing the ball joint it's really not that good. I'd suggest using a two jaw press/puller. You could use it on tie rods too. That way you don't end up with torn boots, damaged threads, and a whole lot of noise. Just my 2 cents though...
Old Feb 23, 2009 | 10:08 AM
Mindgamez's Avatar
Thats Jimmy That worked Great! Never thought to do that. And that Link was GREAT!
MalcolmV8
Apr 5, 2011 09:01 AM
91EF919
16
Feb 12, 2010 12:45 PM
chibiko
Jun 6, 2007 08:45 PM
zccr-xsi
Suspension & Brakes
Nov 10, 2005 08:10 AM
Vp Special K
17
Jan 6, 2004 02:08 PM
