what ecu do i need?
Old Feb 22, 2009 | 02:45 PM
TegraD's Avatar
Default what ecu do i need?
to convert my obd2 shell to my obd1 motor? is it a pr4, a p72?
any help would be tight...
i have a 1994 motor in a 1997 shell and i already have the conversion harness.. im just not to sure what ecu i need to for my 94 motor?
anyone know?
Old Feb 22, 2009 | 02:54 PM
racebum's Avatar
Default Re: what ecu do i need?
if you're chipping a p72-a01 or p28 would work great.
Old Feb 22, 2009 | 03:29 PM
vladd's Avatar
first off, what kind of motor do you have? that's pretty important to know when suggesting an ecu.
Old Feb 22, 2009 | 03:59 PM
racebum's Avatar
quite true. my advice is only for a vtec engine.
Old Feb 22, 2009 | 04:01 PM
vladd's Avatar
it's still bad advice, as the p28 doesn't support the secondary butterflies on the gsr.
Old Feb 22, 2009 | 04:05 PM
racebum's Avatar
if he's using a gsr manifold...which i have no idea where this even came from, chances are the engine will be mostly stock and have no need to be chipped. a stock p72 would be fine.
Old Feb 22, 2009 | 05:13 PM
TegraD's Avatar
nope. its just a b18b1...from a 1994 integra
Old Feb 22, 2009 | 05:19 PM
chevellion's Avatar
I'm having trouble getting my 95b1 to work in my 96LS.
I did the CKF sensor trick. Is the conversion harness really necessary with a p75 ecu??
Old Feb 22, 2009 | 05:30 PM
vladd's Avatar
use the obd1 p75 then. i think you can also use the 92-93 ls ecu but i'm not 100% sure. i also don't know the ecu code.
are you using a 95 or 96 ecu? if 95 you won't be able to plug the ecu in without the conversion harness.
Old Feb 22, 2009 | 08:58 PM
chevellion's Avatar
Its a 96 p75 ecu. The same ecu that was with the original motor.
Old Feb 22, 2009 | 09:08 PM
vladd's Avatar
so you're using a 96 ecu in a 96 car, why would you need a conversion harness? the conversion harness is for using a different obd of ecu.
Old Feb 22, 2009 | 09:10 PM
DC206R's Avatar
welll his motor is a 95 OBD1 LS. and his car is a 96 OBD2 LS so he needs the harness.
Old Feb 22, 2009 | 09:13 PM
vladd's Avatar
how would he plug an obd2 ecu into obd1 plugs? if he wants to run the 96 ecu he'll need to convert the engine to obd2, not the ecu plugs.
Old Feb 22, 2009 | 11:59 PM
delbert's Avatar
obd 1 p75 for ls
Old Feb 23, 2009 | 02:43 PM
chevellion's Avatar
And I swapped the dizzy, intake manifold and starter to be obd2. What else is needed?
Old Feb 23, 2009 | 07:28 PM
vladd's Avatar
i think the alternator might have a different plug and there might be something different about the pcv system. you should do a search because all of this has been covered in the past. i think the starter is actually the same between obd1 and 2 so you didn't need to swap it.
Old Feb 23, 2009 | 07:32 PM
chevellion's Avatar
I did swap the alternator and did the pcv system. I have searched but most are swaps with civics. The new search system blows. Thanks for your help.
Old Feb 23, 2009 | 07:34 PM
vladd's Avatar
so it sounds like you've got everything covered. what's the issue?
Old Feb 23, 2009 | 08:21 PM
TegraD's Avatar
so i need an obd1 p75 ecu?
i have a p75 in the car now... how do i know if its an obd1?
Old Feb 23, 2009 | 10:08 PM
vladd's Avatar
haha woops i didn't realize that i was replying to 2 different people .
anyway, are you going to convert the motor to obd2, or the car to obd1? depending on how emissions is in your area, your only choice might be to convert the motor to obd2. if you're going to do that, then you'll need to use a 96-97 p75 ecu, which will plug into the original ecu plugs that're in the car. if you're converting the car to obd1, you'll have to use a obd2-obd1 conversion harness and use a 94-95 ecu. as i've mentioned you might be able to use a 92-93 ecu as well but don't take my word for it.
if you want pictures of what the different years of ecu's look like then check out this site http://technet.ff-squad.com/
Old Feb 24, 2009 | 12:13 AM
chevellion's Avatar
The car isn't getting a spark. I did the CKF sensor "trick" but used the quick crimps like this write up said.
http://www.scribd.com/doc/2547345/Ho...F-Bypass-Trick
I think the ecu shorted so I bought a new one. Should I solder them this time?
BTW: here is a link to my thread on this issue. Sorry for thread-jacking.
https://honda-tech.com/forums/acura-integra-6/blown-ecu-because-ckf-sensor-bypass-trick-2486996/
Old Feb 24, 2009 | 07:15 AM
TegraD's Avatar
thats cool. no biggie... but thanks i gotta find out what the emissions tests are in arizona then i ll decide what conversion i need.... i qalready have the conversion harness so hopefully they arent to strict there.
Marvlus_
May 23, 2012 05:22 AM
Flava
Aug 2, 2006 08:09 AM
jvonb
Nov 13, 2005 02:02 PM
gser67
Dec 22, 2004 07:37 PM
Todd00
Oct 5, 2001 12:41 PM
