intake piping vs throttle body
Old Feb 22, 2009 | 01:30 PM
NABeastRR's Avatar
Default intake piping vs throttle body
two questions pretty much more for the H series BUT anyone with with info please chim in.
1: ive heard that 3.5 intake will make more hp vs 3 inch intake. ok great can someone show dynos of back to back? cuz I cant find any.
also ive been told to get a 70mm t/b minimum for the H thats great also BUT here is what im trying to understand.
2: If the piping is bigger then the T/B is it a waste or do it kinda have more in there all the time acting more of some sort of charge? will it lose velocity? i know all motor is more about velocity.
pretty much a 3 inch intake pipe is 76.2mm already bigger then most t/bs for honda guys. 3.5 inch 88.9mm going right back down into a 70mm t/b.
Old Feb 22, 2009 | 02:05 PM
Lucid_Dream's Avatar
Default Re: intake piping vs throttle body
yea but you gotta think about one thing that you didn't mention, "ram air" the only real difference its gonna make is it may help create that ram air effect and get more air into your tb faster and of more velocity.
Old Feb 23, 2009 | 03:53 AM
NABeastRR's Avatar
Hmmm yeah i never really thought of that.
bump for any dynos or other theorys
Old Feb 23, 2009 | 04:38 AM
namewasdallas's Avatar
i have no dyno's but id like to say that a 3inch with a v stack tuned length will be best, Length is another factor, at least for were some hp may be. I'm using 3in Vstack on my b16
Old Feb 23, 2009 | 04:46 AM
NABeastRR's Avatar
i have a AEM 3 inch cold air with a BPI stack already but just from researching finding alot of H & K guys runing 3.5 pipes. wondering if its worth the upgrade.
Old Feb 23, 2009 | 07:59 AM
turboedsupe's Avatar
Bump for some real answers. I was thinking of upgrading to a 70mm TB and 3.5" intake also on my bolton h22. Would like to know if thats too big
Old Feb 23, 2009 | 05:26 PM
NABeastRR's Avatar
ttt
Old Feb 23, 2009 | 05:35 PM
JayWest's Avatar
I plan on getting two exact intakes made and testing them out. One will be 3" and the other 3.5". Hopefully ill also be able to test out my 65mm tb with a 70mm tb to see which combination works best.
This will be on my stock block h22 also.
But based on previous threads, it seems the 70mm 3.5+" intake combo is making the best power/times.
Old Feb 24, 2009 | 09:53 AM
NABeastRR's Avatar
about how long until the testing starts???
Old Feb 27, 2009 | 04:12 PM
NABeastRR's Avatar
Old Feb 27, 2009 | 04:59 PM
JayWest's Avatar
unfortunately i dont have an exact date
i want to say somtime next month
Old Feb 27, 2009 | 05:05 PM
chanDAman562's Avatar
how about a 70mm tb and a 3.5 in intake on a "B" is that ok? whats the PRO's and CON's about it?
Old Feb 27, 2009 | 05:20 PM
GoldLudeRay's Avatar
well im running a
4in pipe at the bellmouth of the veleocity stack.... but then it tappers down to 3in at the tb... the tb size is 70mil
aem v2 set-ups us this theory as well
it also depends alot on thim choice
and the size and lenght also can help put the power where you want it
but im useing a pvc pipe set-up to accomplish this so it doesnt look good but it does the job and it will never heat soak
Old Feb 27, 2009 | 06:13 PM
JayWest's Avatar
Originally Posted by GoldLudeRay
well im running a
does it gradually taper or just go from 4 - 3 with a coupler?
i also wondered how a tapered setup would fair
Old Feb 27, 2009 | 06:17 PM
right at the bend where it meets the tb it tapers from 3-4 inside the pvc
u can get couplers that taper from all ranges that are rubber or pvc
Old Mar 1, 2009 | 07:26 AM
NABeastRR's Avatar
if the pvc dont get heat soak & is so cheap why dont alot of others do it?
Old Mar 1, 2009 | 06:23 PM
HAMSTERHONDA's Avatar
interesting thread, but does anyone have some numbers to prove the theory? Is it possible to have intake set up too big? lets say you have a 3.5inch intake with 3.5 inch v-stack on the end, going to a 74-70 mm tb, on a 1.8 liter mild build, 200 hp set up, would you see any benifits or would it hurt the set up , also what part of the powerband would you see the results, good or bad, i know that alot of other factors make a difference on the results, just been thinking about this intake set up ? for some time, any help would be great
Old Mar 1, 2009 | 06:26 PM
if i had a dyno at my disposal, i would def test out diff tb,intake diameter, lenghts and stacks, on a set up to find out,
Old Mar 1, 2009 | 09:28 PM
i was wondering the same thing
it is smooth
i think it is just cause it looks so shitty
and all out drag cars never get heat soak anyway!!!
Old Mar 2, 2009 | 04:40 AM
NABeastRR's Avatar
it is smooth
i think you just answerd it lol shitty/drag car
that takes it away from most street cuz they want the bling factor & drag race cars only run right b4 they go down the 1320.
so im guessing if you dont care about the bling it would be alright!
now we need to find someone wit some 3 vs 3.5 pipe testing.
Old Mar 2, 2009 | 04:55 AM
i know us honda people look for every last hp, but the thing is there is no one answer to say if one if better then the other, its all going to matter on the engine and were it makes it power, which in turn will be at least i would think how you go about length and diameter. im just saying every motor is going to basicaly need something different.
I have a magazine with a b20vtec making like 318hp or something wild and it worked best with like a 4 or 4.5 desil truck intake and filter to work best.
Old Mar 2, 2009 | 05:05 AM
im going to be testing my 4in-3in pvc v-stacked combo vs ebay 3in
this is going to be done on a 12.0.1 motor h22,,,,,, im dynoing on
the 16th of this month
Old Mar 2, 2009 | 08:54 PM
in for some results, some real tech, anyone running a 3.5 inch set up on a 1.8???
Old Mar 3, 2009 | 11:15 AM
angel_i's Avatar
looking forward for the results
Old Mar 3, 2009 | 05:00 PM
NABeastRR's Avatar
i found a guy that did 2.5 vs 3 & claims he picked up 12 whp on a h22.
its a starting point!
