1994 Acura Integra RS
Old Feb 22, 2009 | 11:27 AM
MacDuff's Avatar
Default 1994 Acura Integra RS
Clean title
5 speed manual
141k miles
Lowered on Tokico Blues and RS*R Race Springs
Rota Slipstream 15" gloss black w/ 90% thread left on all 4 tires
Pioneer deck w/ iPod hookup
Everything else, completely stock.
Located in Modesto CA.
Asking $3900 FIRM.
Show up with cash or no test drives. You get to ride shotgun.
PM me.
I've never had a problem with the car starting when its cold in the morning and has to idle a little higher about around 2kRPM's. But I'll drive around for at least 30 minutes park it. Then I'll come back in about 10 minutes, try starting the car, it will start, idle for about 4 seconds then die. I'll then keep turing the key, and after 3 or 4 turns it'll start again and idle perfectly... This problem seems to only happen once or twice a week of daily driving and I'm almost positive its the fuel pump and/or fuel filter. Common problem with these cars I've heard. Other than that, the car runs fine. Never had a problem with it shutting off while driving.
Hatch/trunk shocks/struts are blown and need to be replaced, it will not hold up the weight of the hatch anymore. I rarely have to open the hatch, but when I do I use a vice grip and it holds up the hatch just fine. You can purchase a set of brand new OEM hatch/trunk shocks/struts for just under $50.
The fenders need to be rolled to get rid of the rubbing when turning. Either that or replace it with different springs that don't drop the car as low. Still alright if left alone, but the rubbing noise can get a little annoying. It only seems to rub when turning at 20mph+ sharp turns, and the rub is a very light scratching rub.
Old Feb 22, 2009 | 11:36 AM
bobmugen's Avatar
Default Re: 1994 Acura Integra RS
are you sure thats an rs? they usually dont come with sunroofs...
Old Feb 22, 2009 | 11:37 AM
MacDuff's Avatar
Yeah its an RS w/ an aftermarket sunroof. Previous owner had it installed.
Old Feb 22, 2009 | 07:02 PM
MacDuff's Avatar
bump
Old Feb 23, 2009 | 01:24 PM
MacDuff's Avatar
to the top
Old Feb 23, 2009 | 07:07 PM
MacDuff's Avatar
to the top
Old Feb 24, 2009 | 06:39 PM
MacDuff's Avatar
bump.
Old Feb 25, 2009 | 05:09 PM
MacDuff's Avatar
to the top.
Old Feb 28, 2009 | 07:17 AM
MacDuff's Avatar
to the top.
Old Mar 1, 2009 | 12:22 PM
MacDuff's Avatar
bump....
Old Mar 4, 2009 | 08:14 PM
MacDuff's Avatar
to the top.
Old Mar 6, 2009 | 08:55 PM
thisisareallylongusername's Avatar
trades ? http://hondamarketplace.com/showthread.php?t=2518135
Old Mar 15, 2009 | 04:13 PM
MacDuff's Avatar
Originally Posted by thisisareallylongusername
No thanks.
MacDuff
Northern California (Sales)
10
Apr 6, 2009 12:28 PM
Mad Third Gear Vtec
Mar 25, 2009 09:20 PM
Volko
Oct 20, 2008 11:58 PM
fsarfino
Aug 28, 2002 06:21 PM
