Honda S2000 Honda S2000
HELP! blinkers stopped working!
Old Feb 22, 2009 | 10:03 AM
niccuhles's Avatar
Default HELP! blinkers stopped working!
Like the title says my blinkers stopped working! The hazards still work but the directional blinkers don't work. I searched but couldn't find anything. Anyone have this problem before? What can it be? I'm thinking the flasher or flasher relay, but I don't understand why the hazards still work? Any input is appreciated.
...and yes I did check my blinker fluid, haha.
Old Feb 22, 2009 | 11:37 AM
papa5murf's Avatar
Default Re: HELP! blinkers stopped working!
Check your fuses. You probably have a blown fuse somewhere.
Old Feb 22, 2009 | 11:46 AM
HondaKyle's Avatar
vtec
Old Feb 22, 2009 | 12:27 PM
Stockton's Avatar
Blinker fluid is probably low.
The directionals won't work if it gets to low and only the hazards will for emergency situations but not for long.
Check your local dealership for OEM fluid or you can order JDM fluid online which lasts a little longer.
Old Feb 22, 2009 | 04:18 PM
niccuhles's Avatar
I checked the fuses and all of them are fine. I guess I'm gonna have to wait til the stealership is open tomorrow to pick up a flasher relay.
Old Feb 22, 2009 | 04:21 PM
AP1_man's Avatar
you try changing the bulbs?
Old Feb 23, 2009 | 07:51 AM
White Smoke's Avatar
i my honda
Global Mod
Replacement blinker fluid
Have you checked the connections at the hazard switch to make sure nothing is lose there? What have you done recently, that caused them to stop working?
Old Feb 23, 2009 | 07:56 AM
DevoS's Avatar
Check the connection at the hazard switch. I had to fix mine recently when I was cleaning the center console latch. I put everthing back together and my turn signals no longer worked. You can end up with a bad connection if the hazard switch connection loosens up.
Raguillon
Nov 12, 2013 02:06 PM
newbbsauce
Jun 27, 2008 05:49 AM
otse
Jun 1, 2007 11:23 PM
saanemon
14
May 29, 2003 01:50 PM
scrubachu
Feb 12, 2002 08:24 PM
