obd0 motor in obd1 car??? help?
so i pulled the valve cover off the hatch and it looks like the previous owner took a dump in it. but im purchasing a ef sedan with the same d15b but its obd0.
my question is, how would i go about putting it in my car? i have the dizzy, intake mani, tranny, and exhaust mani off my obd1 d15b. so is it as easy as it sounds and i just throw the long block in or does it need rewiring and such?
thanks.
thanks.
It should be fairly strait forward.
Put the OBD1 engine harness on the OBD0 engine (with OBD1 bolt on's of course) and then follow up with specific questions (if you have any).
reuse your OBD1 Intake manifold, exhaust manifold, distributor, fuel rail, injectors etc. You will also need to extend the wires for the thermo switch from the thermostat housing on the OBD1 engine to the back of the block on the OBD0 engine.
Loccster
Sep 17, 2004 04:09 PM
Civic Hx-T
May 3, 2004 03:40 PM
