replacing power steering pressure hose on 98 accord
Old Feb 22, 2009 | 08:18 AM
jeremyrocksursox's Avatar
Default replacing power steering pressure hose on 98 accord
so I have replaced both hoses before on a 2000 dodge Durango though. but my question is my ps pressure hose went bad and I'm lookin at it, I see how to take it off the pump, but anyone have a how-to or pictures to take the lower part off?
Old Feb 22, 2009 | 09:25 AM
redbull-1's Avatar
Default Re: replacing power steering pressure hose on 98 accord
If I remember correctly:
1. Remove the 2 bolts holding the pressure hose on top of the power steering pump.
2. Jack up car and place a large drain pan underneath near the steering rack.
3. Disconnect the electrical connector to power steering pressure switch (blue arrow is power steering pressure switch, which is attached to pressure hose at the other blue arrow). You will re-use the pressure switch, so get a new o-ring; but, remove the switch after you removed the hose.
4. You may have to remove the brackets (red arrows) holding the rubber bushings attached to the hose.
5. Then disconnect the pressure hose fitting connected to the steering rack.
You will see most of this after you jack up the car.
Mishako129
Jan 30, 2013 08:54 PM
composter7
Jan 13, 2010 04:26 PM
kroze
Jun 1, 2009 09:57 PM
milano2kdc2
Welding / Fabrication
Feb 8, 2006 04:17 PM
