16x7.5 on 4th gen Lude
Thinking of
16x7.5 / offset 42mm with 205/50-16
Currently the car does is not lowered, but in the future will prob put on some Eibach Pro-kit, would it rub? and is the offset okay?
Thank You
Thank You
the front should be okay but the back might rub slightly. if it does then you can roll your fender well up slightly using a baseball bat or roller and/use a camber kit w/ neg setting then get a good alignment after a week or so..
