Knocking. W/ Video
Old Feb 21, 2009 | 09:43 PM
UserX826's Avatar
Default Knocking. W/ Video
I'm trying to find the source of a knock. It's a newly rebuilt block with a head from a motor that broke a rod. I used a stethoscope, thought it sounded like it was coming from the side of the motor around the water pump. I pulled the cover off earlier to run it and see if anything was unusual...
Well.. see for yourself. Warning: The sound will make you cringe. (or maybe that's just me since it's my motor)
http://www.youtube.com/watch?v=JYmU4pbd80A
Also.. You can't really see in the video but the cam gear is moving around. It's not torqued at the moment, but it's as tight as i can get it by hand.
I'm not really sure what's going on. Any help would be greatly appreciated.
Old Feb 21, 2009 | 11:22 PM
trustdestruction's Avatar
Default Re: Knocking. W/ Video
i'd torque the cam gear before i start looking for the noise. are you sure it's not rattling on the cam gear nut?
anyway, could be timing belt tensioner.
Old Feb 22, 2009 | 09:58 AM
UserX826's Avatar
bump
Old Feb 22, 2009 | 11:04 AM
cracker1252's Avatar
look at that belt. i would have to agree...
Old Feb 22, 2009 | 12:41 PM
98civdx's Avatar
Master Detailer
timing belts arent sopossed to do that.
Old Feb 22, 2009 | 12:53 PM
eg6civic1538's Avatar
new tensioner. and new belt is what i would do after you tighten the cam gear down to spec!
Old Feb 22, 2009 | 12:56 PM
random chaos 85's Avatar
that belt is floppin around way to much. u need to take care of that first. its probably smackin the cover.
Old Feb 22, 2009 | 01:06 PM
mcneil's Avatar
I think the bearing for your tension is shot. Or, the tensioner isnt porperly installed. Remove the covers, and ensure its all properly assembled.
Old Feb 22, 2009 | 01:12 PM
Hanmin's Avatar
hmm, sounds like the valvetrain. Videos only help to a certain extent. You ran the motor with the valve cover off? must've been a mess...
Old Feb 22, 2009 | 01:16 PM
it won't make a mess really that much if you stay at idle. i've seen people do it before to locate a problem.
and no, he was saying he took the upper timing belt cover off
Old Feb 22, 2009 | 02:53 PM
green99civic's Avatar
Definitely sounds like you need to tighten that belt man.
donny D
May 26, 2017 07:03 AM
92civicx
Jul 16, 2009 05:37 PM
Tanmt
Nov 7, 2005 09:04 PM
ZEMX3
Feb 22, 2005 06:31 AM
