Quiz: Identify this loose connector!
Ladies and gentlemen we are floating in space...
Just went into the fuse box area under the dash because my driver's side window is stuck down (happens from time to time, but it's freezing out and I can't leave it the way it is) and noticed this. I'm sure it's totally normal, but I'm curious.
Also, any idea why the window switch would intermittently stop working? The motor is fine, and I've taken the switch out and put it back in before with no result. It seems to sort of stop and then start working whenever it wants.
Thanks!
Thanks!
Its a connector to check your codes when the check engine light comes on. Its also used when adjusting timing. By jumping it you stop the electronic advance. It can stay unplugged. It actually only goes into a holder to keep it out of the way.
You're probably right about the switch going bad. Seems strange that it works fine most of the time though, doesn't it?
All this still leaves the mystery connector, though! It's blue and located right near where OEM fogs plug in.
James1031
Sep 22, 2018 12:59 PM
Rob.
11
May 18, 2016 04:27 AM
