Need help with HID wiring harness.
I'll try to make a long story short with just questions and concerns. Just a quick note, the harness only has one relay (if that makes a difference?)
1 - I purchased a custom harness for the HID's from a vendor on EPHatch.com. It has the low beam wiring and the high beam wiring. I'm good on the low beam but can not figure out what kind of bulb goes into the high beam. I was told a 9005, but the 9005's have two prongs. Here is a quick pic of that:
2 - When I have the low beams on and press back on the high beam switch and let go, the lights either a) don't come back on (unless I flip the headlight switch on/off) or b) only one side comes back on (And then I have to turn the headlights off and back on)
3 - My dash high beam light is alway's on, but very dim, when I have the headlights on low beam.
4 - The passenger side HID look's like it has something blocking the bulb because when I have them on, its just not light much more than 2 feet in front the car.
So should I make another relay, make bigger gauge wires? I can not figure out what to do.
Mr. Samurai
12
Oct 5, 2011 10:57 AM
bz_kurb
Honda Civic (2001 - 2005)
Aug 29, 2008 06:20 PM
